yawdapaah
Android Expert
Hi Guys,
Well NexTheme for ApeX is (hopefully) done. The original theme had an extra 9.png that wouldn't even decompile. Seems to be all good now; I've been running it since noon.
MAKE SURE YOU HAVE STOCK NEXTHEME FOR APEX INSTALLED. NEXTHEME MAKES CHANGES TO BLUR-RES.APK SO YOU MAY BOOTLOOP IF YOU'VE MADE ANY CHANGES TO NEXTHEME.
It is advisable to install these mods after REINISTALLING Fab's original Nextheme (ApeX or STOCK) themes.
Full instructions are up for those who want to do this themselves.
Enjoy.
Blue battery framework-res.apk (use adb)
White battery framework-res.apk (use adb)
Fab_NEX_ApeX_10%_MOD_B.zip
Fab_NEX_ApeX_10%_MOD_W.zip
Multi-colored version by mxsjw
Fab_NEX_ApeX_10%_MOD_MC.zip
FOR STOCK FROYO WITH NEXTHEME ONLY
Only use the stock version if you're on Stock froyo with Fab's Nextheme installed.
White battery framework-res.apk (For those on stock Froyo with Revo theme) - use adb
Fab_NEX_10%_MOD_W.zip (For those on stock Froyo with Revo theme)
Decompiled XML files
Grab the rEVO version here!
DISCLAIMER: I am not responsible for anything that may go wrong with your phone. If you don't know how to restore your phone, don't try this...yet
Requirements: Rooted, Koush's Droid X Bootstrapper, Fab's NexTheme for Stock or Apex rom.
Instructions
1. Download the .zip file to your sd card
2. Reboot into Clockwork recovery
3. Go to system and mount and mount system (should read unmount if done correctly)
4. Go back to the main menu and Install .zip from sd card
Thanks to:
Fabolous - for a great ROM and several great themes.
aflat - partner in crime; helped me figure this stuff out.
Fightspit - for the great icons
Qliratu - for the online cooking tool. Use it to generate your battery pngs. UOT Kitchen
Enjoy.
.Requirements: Rooted, Koush's Droid X Bootstrapper, Fab's NexTheme for Stock or Apex rom.
Instructions
Thanks to:
. Let me know if there are any problems and I'll try my best to fix them. Hopefully, this won't be necessary with Fab's next iteration of NexTheme and Revolution.
