Wont let me place the call keeps saying no sim card
Fuzzy I was root and had a custom ROM (forget which one) when my phone was working fine, then I tried to factory reset it , got stuck in CWM then did some update program (ran it from my computer) and it got me unstuck from CWM then this happened (the no service)
I've TRIED but remember i have no SD card so idk how else I can do it :S
Fuzzy can I please add you to MSN or Skype or something quicker I can talk to you on?
i remember troubleshooting a esteem with a similar issue.
-take the UICCID card out
-boot into recovery
-do a hard reset
-i dont remember if after the hard reset the phone powers on or goes back to recovery, but if you see it booting back on, take the battery out.
-now put the UICCID card back in and boot up
-report back
hi monica, im gonna chime in since this exact thing happened to me. im assuming since your in the esteem forum you have an lg esteem. get an sd card with an adapter to plug it into your computer. from this forum dowload a rom and kernel to the sd card. then take your battery out and put the sim card in. it goes in the little silver place next to your sim card or what ever they call it card. put the battery in. hold down the volume buttons and power it on. as soon as you feel the phone vibrate let go of the power button but not the volume buttons. this will make the phone go to a screen that basically says erase all data. push for yes. after you do this it will reboot into cwm recorery. from cwm recovery wipe data, wipe cache, and wipe dalvik. after doing that go to install zip from sd card and do it. i know you said you dont know which one you had but i started with a black plague rom and kernel and now have #2 from ldrifta. pretty much what you said happened word for word is what happened to me. good luck.![]()
It was in backwards.
Now he's stuck in a cwm boot loop with no sd card. Least he was last night
Wait a minute......he? As in "male"?......monica?
