Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
It actually is mentioned here a few times :p. Use Google Adb drivers instead of LG drivers. It should do the trick.
What about the Link2SD script error?
Installing BusyBox doesn't work either.View attachment 106619
Hi, I've never had such problem with BusyBox (D320N, CM13).
Did you use the "Smart install" or manually clicked Install button without waiting. The former is searching your system to see what components are needed, whereas the latter installs it all without performing the check. I've always waited and used the Smart Install.
BTW, your attachments are broken - cannot open them.
I clicked install when I fully loaded the app to 100% and clicked manual installation. Still didn't work as you can see.
Dont know if BusyBox has a correlation to the Terminal, but no commands work so that I can fix Link2SD as well.
Some one else have noticed the notifications/quick access bar is wider on horizontal rotation??? :^)
BusyBox has no connection to the terminal, that is, it doesn't check if your terminal is enabled or not. I just used the same terminal command as you and it worked without any problems, so..
Don't know what can be wrong with you device.
Can you explain this?
huh, I just wrote I can't tell what can be the cause of your problems :) Sorry, bro.
I don't have such problems with my phone and never seen such Terminal error. I just checked it myself and it works.
You may try flashing a different nightly or wiping cache + dalvik/art cache from within TWRP.
Maybe someone else can offer a better idea.
Important question, how do you flash a nightly without losing any data exactly? Cause if I do, I will hate going thought the setup process again. I know there are answers to this, but there are over 58 pages! Whew!
You just "dirty-flash" it from withing TWRP, i.e. without doing a factory reset or wiping anything. It shouldn't remove your data but make a backup nonetheless.
Like Mystery said... Busybox binary isn't installed, only installer apk. Weird thing no having space in system/xbin. What about partitions allocated space? Never happened to me...
You don't want to loose data so try wipe/dalvik and wipe/cache , reboot
Reboot again .. hope it help you...
someone has an idea how to create the script, with the application app2sd, now in the last update, I get error partition, Can anyone help me?
I had updated my D320n to the latest nightly (cm-13.0-20160709-NIGHTLY-w5.zip) and after that I found several bugs:
1. Home button don't return me to the home screen, although long press is still working
2. Navbar drawer bug like here
3. Lock screen won't appear, pressing power button will show home screen instead
4. I can't change usb settings
I had read I should install nano gapps instead of pico, but that didn't work. Should I wipe the system and do clean install?
