Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
The screen says you have no BusyBox installed. That's why the command doesn't work.
Have the app since I have
unavailable space in system/xbin. But even then, the command doesnt work with or without root.
Can you explain this?
Like Mystery said... Busybox binary isn't installed, only installer apk. Weird thing no having space in system/xbin. What about partitions allocated space? Never happened to me...
You don't want to loose data so try wipe/dalvik and wipe/cache , reboot
Reboot again .. hope it help you...
someone has an idea how to create the script, with the application app2sd, now in the last update, I get error partition, Can anyone help me?
I had updated my D320n to the latest nightly (cm-13.0-20160709-NIGHTLY-w5.zip) and after that I found several bugs:
1. Home button don't return me to the home screen, although long press is still working
2. Navbar drawer bug like here
3. Lock screen won't appear, pressing power button will show home screen instead
4. I can't change usb settings
I had read I should install nano gapps instead of pico, but that didn't work. Should I wipe the system and do clean install?
I bet is a Recovery problem, I guess you have CWM recovery you have to change it to TWRP, then reinstall the nightly and everything should work
The nightly with the huge ass changelog from some days back introduced wifi battery drain for me, latest fixed it, just a heads up
First of all id like to thank you for great ROM. I am using it as daily driver for months now, and its been great. I have a problem that is annoying as hell. It seams that for no particular reason at some point the sound for ringer dies. The phone is ringing but there is no sound, like its muted. If i go to the settings menu and and try to change the ringer sound there is no sound preview. If i try notification sound there is a preview, i can hear the sound. If i try to play music over Aimp at that time its working over headphones. Problem exists only on ringer and i think on alarm too. Sometimes it simply doesn't ring. I think that animation for alarm shows up, but there is no sound.
The only solution i found out is that i have to restart phone and then its working again. Is there anything i can try more? See any logs? After a few dirty flashes i have tried with a new clean install. Sometimes it happens in a day sometime it works for a few days... I'm on 03072016 nightly, and have formated sd as internal. Internal is 780MB/1.50GB and SD is 2.75/8GB. Any help would be appreciated.
Hi, I had a similar problem with some of the nightlies. I've been using 2016-06-10 for a long time without problems and now 2016-07-09 (it's doing great).
I'm pretty sure you need to upgrade to the 2016-07-09 or newer version. I use alarm clock everyday and have no issues :)
BTW: make sure your recovery is up to date - TWPR 2870 or 3.02 is required.
Thx for fast reply...
Yup TWRP is latest 3.02.
I guess ill try again to flash new nightly.
CAN SOMEONE HELP ME?
I'm stocked on a old version and unable to update CM, when I did reset my L70 D325, the recovery TWRP doesn't work since then, just keep on bootloop and don't get into it, I already installed cmw and it worked well but I can't update the SO...
If you use SD card remove it from your device and try to get into TWRP.
All it did was reset CM 13 like if it were new *sigh*. (P.S. on TWRP I went on Wipe then Advanced Wipe. Once on the menu I selected Dalvik/ART wipe and Cache Wipe.)
So sorry it actually went back to my original state as I had left it. Even then, the error remains the same :(
i have problems to install Link2SD, says "no such file or directory" i tried wtritte the comands in terminal, but don't work
help please!!!
I am having some issues with play store in CM13 . Will flashing G apps again via TWRP remove all my installed applications?
I have installed CM13 using CWM recovery mode. Every thing is OK but there is only one problem!
I don't have menu button! Menu button work as Home button and when i press Home button, one of items in the current screen (e.g. icons in home screen or list items in settings and...) highlighted (selected).
And also when the phone is in sleep mode, the home button don't have any affect!
How can i solve this problem? Home button work as home button and also menu button as menu button.
Thanks
