Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Again after full wipe installed this cm-13.0-20160723-NIGHTLY-w5.zip and the same thing happened. When it boots up, on the start screen language selection, I can't tap on "Next" because when I tap on it the pull down menu is showing on top of the screen and that is it. Also the phone is getting hot as hell! Can anyone confirm this or is it just my phone?
I've never had such problem, D320N. You may try with some older nightly, 20160709 is perfect for me.
This one cm-13.0-20160720-NIGHTLY-w5.zip is the last which works for me. Never had a problem, because I allways clean install every nightly as it come out. The last two have some "bug" when clean install, and heat up the phone pretty much. Maybe only with the "dirty flash", the bug don't show itself!
Also, currently in Cyanogen Inc. in affect is a massive layoff in all their offices around the world!
http://www.androidpolice.com/2016/0...undergoing-major-layoffs-may-pivot-to-apps/#1
@vm03 I found small bug. In headphone buttons vol- doesn`t work. I have Xiaomi Piston V3 headphones. Button volume down work in stock and cm12.1 by @vladimirs77
Just wanna share this alternative method for Flashing Nightlies zip, tested 100% works by me
Especially for those who use Adoptable Storage
As we all have known that TWRP, even the latest (3.0.2) doesn't detect the adoptable storage
There's an app FlashFire: https://play.google.com/store/apps/details?id=eu.chainfire.flash
I successfully dirty flashed the nightly zip dated 27/7/2016
I use the menu: Flash ZIP or OTA of that app (the app can detect adoptable storage as well)
But before you can use the app, you have to change the SELinux mode to permissive, using the app: SELinuxModeChanger
Good Luck for those who wanna try it!
I m updating nightly every day with own updater and i dont have problems d320n
good luck and keep good working vm03 you r the best
Hello folks. Do you have any idea when the next stable CM13 release will come out? Current release is from 2016-04-18. I would like to update my wife's phone, but I wouldn't like to use nightlies in her device.
Hello everyone. could someone tell me if I can flash an .apk file as .zip with TWRP
In order to flash new Google launcher.
Might be a silly question, but do you mean compressing an apk to zip yourself, or you just have a flashable Google Launcher version?
This zip must contain a install script that works from within a recovery and a specific structure of catalogues, so if you are simply compressing it yourself, it doesn't work this way ;)
There are tools for it.
My question is because I want to install the new nexus launcher and found a post that says that to get all the properties of the new launcher must install the apk file with TWRP
There's no direct way of installing apk from within a custom recovery. As I said, there should be a flashable version they talk about.
If you want to experiment just install,not need TWRP.But I warn you,when uninstall nexus launcher,Google will be uninstalled too.
  • nexuslauncher.apk
    nexuslauncher.apk
I installed latest nightly 20160803 and everything is ok but after flashing super su 2.76 process system not react
and after i press wait then after few seconds go to blue cm guy and wont start i remove battery and start again and then works good, so do i try with super su beta or something... can someone help me
