yes cm6 is clock to 710 with setcpu but 600 is default, cm7 is set to 600 default but you can change it in cyanogenMod setting, without setcpu.
CM6 is 710 default. I have too use setcpu to bring it down because my main Ascend isn't stable at 710.
:Xhi this my first time here. so i just want to say that my friend works at metropcs cor,store and he said in cobbleweeks we have to go there and get update to 2.2
gets warm n crashes most likely lolWhen you say it isn't stable, what exactly happens?
CM6 at 710 on my Ascend would cause lock ups and crashes... dropped it to 653 and it ran much better, and only had an occasional lockup, especially when exiting anything using internet... it would freeze up the home screen and ask if i wanted to "force close" the CW, but i would hit "wait" instead, and about 10 seconds later it would be fine... running at 600 cm6 kicks ass!!
+1 my ascend likes 710 just fine too.had mines set to 710 and no problems, but everyone ascend is different, some cause problems at 710 and some dont...
Well mine randomly reboots, or would have problems running apps. It takes 4 or 5 attempts to boot up.
I too have had the random restart, and a "boot loop" or 2
-same heremines love 710...anything lower my phones swear at me. lol
So I got cm7 on my phone and its awesome!!
but I would like to if there is a way to get the apps that came with the phone when I bought the phone like the cricket account app point and those other apps
Which apps other than POYNT & CRICKET'S 'MY ACCOUNT' were you wanting to re-install?
POYNT can be d/l directly from the market.
As far as the CRICKET apps go,hopefully someone here can provide the apks. for what you're wanting.
Well just the MyAccount and MyBackup(found the poynt app) so yea I wud really appreciate it if someone found the apks![]()
