nuttmeg
Extreme Android User
There was an update for the ascend...? I didn't get any notification. Lol.
no, it was metro playing games again.
I agree with the general consensus and believe their will be no update for my Ascend , so I did the manual upgrade to (CM/7) 5/14/2011 build and my phone works great. MMS is fixed by flashing second zip file (MetrOFF 1.3). This mod is great and I'm a noob to this kind of thing!
MAN!! I'm really starting to not like my ascend... so, can cricket users get the metro update of the 2.2? if the link is true? I know nothing about this stuff...and I'm mad that there's talk about no upgrade.ugh!
I have serious doubts cricket will ever provide an update for this phone. They will just try to sell us the new one when it comes out. Call me a cynic, but...
Follow this thread: http://androidforums.com/ascend-all-things-root/320265-ultimate-ascend-customization-guide.html
It will provide you information on installing different ROMs.
its not complicated at all, but you should be comfortable with the steps b4 you attempt it.Thats what I mean... I have seen this guide before but it seems complicated, then the laptop where I'm looking at these forums is borrowed. I think i would just mess somthing up.
this is really confusing, metro y so complicated?
Just get rom manager off the market and get CM7 (2.3). The app will do the whole thing for you, as long as your rooted of course.
wow, i think i got it! went over and over the forum guide and i believe i finally did it. thanks to evryone here that helped out.
One thing i dont understand is why my 2 gb sd card is almost full...i plugged it in the pc but nothing shows up? then i turned on usb storge and got a "open devices and printers" but i cannot see the files on the sd card?
you have to click open to view files, or go to my computer and doule click the sdcard, problem solve...
tried that when i select "turn on USB storage"...but instead of showing the sd card, under My Computer this is what i get. "Android Mobile Adapter" with a picture of a disc drive and only shows its properties. no files.
what build you on? and what os you using on computer?
Sorry whats a build? lol ... are u talking about CM7...thats wat i havethe laptop is a windows 7...and before i did evrything..it worked because i remember copying files from some pictures i stored in the computer.
are you on stock 2.1, cm6 2.2, or cm7 2.3, but what you can do is uninstall the drivers and reinstall the usb drivers...
