80sMetalHead
I had the same issue with no data after flashing from CM7 to the PlayfulMod-1.0_signed.zip. Looking at the APN settings there were none to be found after the flash. I tried the Metr
FF fix for CM7 but that did nothing at all.
Here is what worked for me:
*228
Option 5
Option 1
After phone rebooted:
Open APN's and add...
APN: <Not Set>
Proxy: proxy.metropcs.net
Port: 3128
Username: <Not Set>
Password: <Not Set>
Server: <Not Set>
MMSC: http://mms.metropcs.net:3128/mmsc
MMS Port: <Not Set>
MCC: <Not Set>
MNC: <Not Set>
Authentication Type: PAP or CHAP
APN Type: *
You will get an error that "The APN cannot be empty." Just hit OK and then END.
Go back to APN settings and MetroPCS should be in the list. If there is no green dot after it, just put it there.
I am not sure if both steps above are necessary but it worked for me and I currently don't have time to replicate the flash and try each seperately.
Hope this helps.
FF fix for CM7 but that did nothing at all.Here is what worked for me:
*228
Option 5
Option 1
APN: <Not Set>
Port: 3128
Username: <Not Set>
Password: <Not Set>
Server: <Not Set>
MMS Port: <Not Set>
MCC: <Not Set>
MNC: <Not Set>
APN Type: *
Hope this helps.
