PlayfulGod
Extreme Android User
u can simplely delete the whole metropcs dir too
The update is technically outside of Cricket and Metro's hands Huawei is doing it. (Which is why they upgrade before the Kyocera droid, cause it's the brand not the carrier doing the upgrade) As for self-righting this, there is no way...technically. The Ascend has this cute little "**** you I quit" reset feature. Which is, when the power is off, press and hold, [Power ] [End], [Volume up], keys. Factory hard reset, you have to call metro to reactivate the phone or take it to cricket/Metro and pay a little for them to do it. but you save your phone. Rooted or not you'll get it back brand spanking new and have to redownload all of your aps and whatnot.
More on that here.
How to format or Hard Reset Huawei Ascend | CellphoneDaily.com
Hi I am a cricket rep and I had a customer trying to use bluetooth voice command on the Ascend. It seems as though the version 2.1 android OS does not support this feature. I continued in my search to help my customer use this feature. So with this in mind, does ANYONE know how to get the bluetooth voice command to work on a 2.1 OS???
the official froyo update has finally been released simply go to the metro app store on your phone and click on ascend software update then follow the instructions on your phone... its about damn time they finally realeased it...
Note: it is not in the android maket it is in the app store on your phone. if u have any trouble finding it on our phone check out this link Huawei Ascend (MetroPCS) Android 2.2 Froyo Update Available [Download] - Gadgetian
If its huawei doin the update. . Umm why they only do it for metro... ppl make no sense!
Because Cricket is greedy. They want to make you buy another phone... I'm just going to wait a little longer, and if they don't release the update soon, I'll just join the rest of the majority and root it, rom it, and get rid of the bloatware and be happy.![]()
I've had no issues using any version of CWMR. Metro did the same crap with the TOE, and I've been saying they would prolly do the same BS with this and they did. But its like me and many others have said, CM6/7 is the best ROMs out for the Ascend hands down.Ok so like i have said. I downloaded it when it was first available, used Gingerbreak to root it. Then had to use Root Explorer to make the directory R/W so i could delete out all the metro crap ware.
Boot Animations still sucked, boot time was still incredibly slow.
Oh and once you do the upgrade CMR 2.0 no longer works on your phone you have to use one of the 3.0 versions...Learned this after flashing it back to 2.1. Somehow if you do the upgrade they have it hard coded to still screw you over.
Overall Metro did what they said they would do. They did issue a 2.2.2 update, and the way they hard coded and hid everything shows why it took so long. Basically they wanted to make it impossible for people like us on the forum to customize the phone to our liking.
