nuttmeg
Extreme Android User
Is gingerbreak rooting working on others that have upgraded to 2.2?
it works flawlessly...
I went to the Metropcs.com website and went to my phone and the uodate was available. I did the download the LEGIT way and my phone runs great!!
nuttmeg - With gingerbreak, is that a permanent root? Z4root was nice, becuase I could unroot if i needed to take back to MetroPCS store. Just curious. Thanks
Ash,
Yeah. The instructions are here but swtich setp 3 with 4. That will ensure you know its working. Just be sure to pull the battery and leave it out for 10 seconds. It works.
No.. I want to know how to download the official via internet. I'm too busy to go to Metro now.. (BTW I'm a kid, my technology area isn't bad, but it isn't advanced either..)
just follow these step and it will put you back at 2.1, than you can retry putting 2.2 back on there.
reverting back to stock, ok power down the phone and download and extract this to your desktop MetroStockRecovery-SCRIPTS.zip after you done that press and hold vol down, end key and tap power, your phone should be on the white huawei screen and it should stay there, now open the folder that you extracted and run both of these file, first run fastboot-windows you will see a black box come and leave quick, next run metroPCSStock-windows.bat than another black box will pop up and it will do its thing, once it finishes the phone will automatic reboot itself.
than you can use option 2 to install from the main page here Huawei Ascend Android 2.2 Upgrade
Could you tell me how to get the one from Metro? My dad wants me to go to a stable operating system.
I did what you told me and now its stuck on the android screen....
