Root Okay I surrender pls help
it was went through all the updating process asked me if i wanted to reboot hit yes started to reboot thought mu nightmare was almost over then vibrtaed 5 times and back to nothing
wait a minute the sprint logo is starting up maybe just maybe did another battery pull its trying
i dont understand it booted up pulled up the set up screen tapped set up google account then back to virate 5 times then nothing b maybe one more time that 5 times vibrating must mean something
Battery almost dead when i plug it in it wont charge
i'm sorry when repling to a post do i just hit edit then save ...?
guess i jast answered my own question
it says updates complet but bootloader bypassed...?
I think i placed something on my sd card over the last 4 days thats doing this should i try and remove all the roms and theres another 3 mg pc36img on there ....
Bootloader bypassed should i try and reboot it anyweay again it will be the third time...???
and ideas ocnbrze pls i know you are very busy but i am literally hanging on your every sentence ..?
okay tried like 4 times at the end just vibrates 5 times led blinking then nothing
OMG i thought you where done with me it keeps bypassing the bootloader says update complete do i wanna reboot tried like 5 times now keeps giving me the same result
ok it will keep asking you that every time you go into the bootloader because of the PC36IMG file. you can just select no. however, if this file worked then you may not have any recovery to go to. what happens when you go into recovery?
allright this whole mess started at around noon on friday im so wiped out dont suppose anyone could call me help me out at leats let me know if my phone is done
i never tied it phone completely shuts down i just did another battery pull don't know how much longer my battery is gonna last to answer your question i just got the phone icon with the red triangle i type type with 2 fingers and i am very slow so pls bear with me
i could be wrong but i think theres something that i put on card thats doing this also even though o renamed the file when it starts to update it syas zip at the end but if the file wasn't working then it wouldnt even tryu to update would it
i even tried to pull a back i made of phone that was in clockworkmod folder that i made yesterday did nothing i that sounds stupid but i tried
I really am lost if all these files are on on phone that was there forever something should work...?
gonna try one more battery pull i'm beyond lost
ok the red triangle is good. that means that the file worked to some extent. it was supposed to do that. try rebooting again and see what happens.
sorry ocnbrze but are you still with me ...?
okay
Okay again it went through all the motions even got me to the set up screen like before then try to hit okay about google locations as if i whre setting up my phone then it does the same thing 5 beeps then nothing battery is 99% dead but if you go back to the posts it did the same thing about an hour a go so i dont think its the battery but when i plug it in it won't even charge
I know this sounds stupid but why can't i get the battery to charge anywhere plug into waLL nothing computer nothing it won't start to charge ....????
ocnebrze pls anything i have to get up at 5 am to work use my phone alot as i am a contractor i just need to know if my phone is bricked pls my nerves are shot had the phone along time tried several rom switched several kernals no problem then this
still with me ocnebrze ....?
Can you pm me or me pm you in ever i did that but i c alot of people doing it i assume its like a private intant message.???
okay
ok i think i know the problem then. try a different battery and see if that helps. i had a battery that would charge to 100 then be dead in like 15 min. so if you know someone that has an evo and you can test the battery or try buying it from amazon. Amazon.com: HTC Standard Battery for HTC EVO 4G: Cell Phones & Accessories. they are cheap and fast. i got mine in like two days. i think your phone is notbricked and that this is more of a battery issue.
okay can someone pls tell me how to get the battery to charge while in phone i do not have any other charger for battery
well even when i got to the set up screen and put in my google information and password it kicked back and said wrong info is that because phone has different esn or something ....? thanks for your help as always gonna hit the sack been a very long 4 days ty ty ty very much hope maybe i can get a battery and try again i dont think thats the issue like i said it did the same thing to me an hour or so ago cant thank you enogh for trying TY TY TY wish the results where different got ito most of this trouble besides alot of other things after all this time having myphone because i was hell bent on partioning my sd card ty again maybe you can help me another time night
Okay okay forgot daughter has my old hero and has same battery swapped batteries phone booted up was almost finished set up thought i was home free when i was signing into google did the same thing have fresh fully charged battery in it it stops vibrates 5 times then nothing any ideas i have a freh battery in it ..?
If im bothering its okay just tell me , ive seen so many people helped out on here , if i'm bothering pls tell me and i'll just let it go but now i know its no the battery then there must be an answer and if there is one either you or frenchy or so many others on here that i c all the time should be able help me out again if im bothering you i understand
this might sound weird but i'm reoading my phone for the 7th tine with the file you gave me but it still says {PC36IMG.zip} you think thats the problem..?
It keps skipping the bootloader when updating...?
it keeps bypassing the bootloader ..?
that is interesting. out of curiosity put the hero battery back into the hero and see what the battery level is.
its about 75 %
put it back in phone this time wouldnt even let me get to google sighn in .?
crazything is the led keeps blinking green like the phone is on and evything is working but other theb that if i want the phone to to anything i have to do a battery pull
as long as you have the PC36IMG file on the card it will always ask you to update. not sure what you are trying to do. try doing the one for amon ra 2.3 if you still have it and not getting all these files mixed up.
