that is interesting. out of curiosity put the hero battery back into the hero and see what the battery level is.
I don't get it the 5 vibrates must mean something ....
ok i just wanted to see if it was draining the battery at all. try my suggestion of getting a custom recovery on it now.
i do not think that is the issue though.Maybe you can try skipping the google sign in and see what happens.
you need a recovery first. did you get amon ra installed and working?Okay i just put mic g 2.5 sighned now what ..?
follow the http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html and go to the switching recovery section to get amon ra
yeah i did not think that will work. try the amon ra recovery
im just paying close att to this problem for future reference.It was worth a try but of course you were rightim just paying close att to this problem for future reference.
i THINK I KNOW WHAT THE PROBLEM IS MAYBE I'M CRAZY sorry for the thcaps i have to look at my keyboard when typing even though i rename the amon ra zip and rename it PC36IMG when i place it on the sd card and run it it has zip still attatched to it there are several copies of it on my sd card i tried to delete some but it wont i dont know i downloaded it again renamed it placed it on my sd card it says copy already on there do you want to rplace it say yes c what happens but they are on my sd card ...?
says
even though you rename it does it act like a zip file and say PCIMG.ZIP anyway its reupdating for the 7 or 8 th time .?
do i want to reboot device ..?
yes it is on card should i try another reboot im afariad i'm just gonna get the same resultsok that file looks like it is for the stock rom i gave you. that is fine if you want to see if it worked finally. but i was hoping to see if we can get amon ra installed instead. do you still have that file?
