Root Okay I surrender pls help
ok i think the issue is that we might be mixing the files. delete all of the PC36IMG files from your card and lets start over. download the amon ra file and rename it and put it on the card. and try hboot again.
ive tried several times to delete them several for some reason they wont delete if i drag them out if sd card computer just says copy..? been trying to delete them since we started as i knew this may be a problem
i mean its all still on my sd card everything i know this sounds stupid how do i delete those files.?
Phone acts like its running led flashing green but nothing else .........??????
I am way beyond frustated and last sugestions and i thank you very much for your time vm greatly i gotta hit the sack soon i have the very very sick feeling in my stomache this has bee to much
ok but you have stock rom and a STOCK RECOVERY which will help you if you want to take your phone in. it could be a hardware issue for all i know. take it in and just tell them that you can't boot up your phone. they more then likely will not look to see if you have s-off or not.
right click on the file and select delete.
okay i knew that was a dunb question i had like 15 windows open i thouigh that might be an issue i deleted them all redownloaded 1 placed it on card we'll c i just tried to start phone it just gave me the 5 beeps i have tep but i'm afraid they might say we'll have to send it in for repair gonna try updating one last time then i'll consider it bricked thanks i cant thaqnk you enough guess thats it i'll try on last update then i'll call it a phone tyh ty ty
you should be good to go since you do not have a custom recovery. i have seen people send them with s-off but no recovery and was able to get a replacement. keep us posted. and sorry i could not help you. we tried at least. now get some rest.:)
