Root optimus 4x hd bootloader unlocked
That may work for us. Adb reboot boitloader, fastboot OEM unlock then enable unlock.... from there the hidden menu shows unlocked.... I don't have my desktop to test this or I would right now
Well if somebody is brave enough to test make sure you have fastboot drivers installed as well.
i got 5 bucks on you get a ...
....nevermind, it will be more fun this way :)
you lose :p
Update, did fastboot oem unlock and command went through, flashed boot.img after and it's exactly the same, need help determining if I am unlocked...
edit: duh....video.apk :p
flashed recovery
it had the regular prompt, after pressing power button twice, it booted into a garbage screen....is that good???
edit: no adb either
