Help Please help asap!!! Apps going crazy
cwill134
Ive searched all over google and cant seem to find anything on this topic. The past couple of days my phone has been going very slow and acting weird so i just noticed that when i opened my task manager all of my apps are stuck on restarting, therefore whenever i open an app it will close and then re open. I did a virus scan witg avg and nothing came up. Ive also done a factory reset and thag didnt work neither. I cant use any of my apps without them closing on their own and reopening and more than usual my apps keep freezing and i have to force close them.. does anyone know why my apps are stuck on restarting, all of them!!
welcome to AF!!!!!!!
what phone do you have? how much memory do you have left? is the phone rooted? are all the apps like this? maybe a factory reset is in order?
Its the lg spirit. Every single process in my task manager is stuck on restarting. I did a factory reset and it workes good for maybe the first day and now its back to doing it. It makes my phone freeze up. Ill open the internet for example and it will jus exit and then it looks like my home screen refreshes as well..
you may need to use the unbrick/unroot/return to stock method. http://androidforums.com/spirit-4g-...ricking-unroot-return-stock-lg-spirit-4g.html
