Root [Port]Paranoid Android Motion[Port]
TheDemon
Jellybean(Android 4.1.2)
ParanoidAndroid(2.52)
(Base)Builder: Playfulgod
(Rom)Builder:Not exactly sure..
(Porter)TheDemon
Current Version: Pam-06_14_13-252
==== '''People owed thanks to:''' ====
CyanogenMOD
People that made Paranoid Android
Bobz
PlayfulGod
hroark13
985hPaKicK
qaz753
alexp999
Sammyz
aaronmy
About
To be honest, this is not tablet mode at all, it has nothing to do with silly build.prop hacks.
This is the first and only Android rom to feature true Hybrid mode.
This rom lets you scale and project every app, every widget, even systemcomponents individually.
Remember, android is modular, everything is an app: Lockscreen, navigationbar, dialogs, popups, keyboards, widgets, and your regular apps of course.
Apps have the capability to switch into various designs or layouts according to the device they run on.
This can result in a complete new experience as many apps will transform to the better.
Now for every element that you like chose a mode (PhoneUI, Phablet/Nexus-7UI, TabletUI) and/or a size.
You are 100% independent of the system DPI which runs nicely in whatever value it has been assigned to.
You do not need to boot your phone into a certain DPI. Neither will most of the changes you apply require a reboot.
You will not suffer from the myriads of troubles which normally haunt you under build.prop tablet mode.
Your market, phone, etc. will all work, apps won't shrink on you unless you shrink them yourself.
This project will entirely transform your device, but retain the aesthetics and the feel of your phone.
Downloads​
Gapps- Link
Pam-06_14_13-252.zip - Link
Pam 6/15/13 - Link coming soon
Old Downloads
Tips​
6/8/13#1- I wouldn't mess around in the workspace settings if you don't know what you're doing. You could really mess up your UI(Make sure to backup)
6/8/13#2-Do not reboot into bootloader(Factory resets)
6/14/13- I recommend using a different launcher as default because low dpi causes the wallpaper to go black. I recommend Nova Launcher.
N00b install steps​
1.Backup apps and app data (Titanium backup recommended)
2.Backup rom(Cwm)
3.Clear data/cache(factory reset), clear dalvik cache, and format system.
4.Flash Pam-06_08_13-252(Link above)
5.Flash Gapps(Link above)
Changelog
Pam 6/14/13 - Added PG's Mms.apk Added Apollo.apk from cm10.1, edited default paranoid android conf settings, and some minor unnoticeable stuff.
Pam ?/??/13 -AGPS Patch, New Paranoid Android features(Per-App COLOR (newest PA invention)), Fixed Paranoid Android preferences. And minor changes
Next Build: Fixed Camera and audio problems.
Looks and works great so far I'm going to use it for a few days to look for bugs. But I'm loving all the options. Great work.
Im curious to how this is compared to the other CM10 roms.
Looking forward to what everyone else thinks about it after testing a while.
Nice work.
I think this is great, just that our screen is way too small so we can't really enjoy its features to the fullest but other than that, great rom :)
The media fire link says authorize download but never loads up a authorizing screen
Why? Can someone repost the link again?
Nice work.
I will echo what LMAOseph is asking; how is this compared to the straight CM ROM (ie 4G, sound volume, etc).
I will echo what LMAOseph is asking; how is this compared to the straight CM ROM (ie 4G, sound volume, etc).[/QUOTE
It uses pg cm10 as a base so all known bugs with that will babe in here. So far picture messaging does not work but that's fine, my call volume seems good and GPS is not working other than that is its great. Great speeds no reboots its a great start.
Paranoid android is based on cm, but its big thing is that you can set display options per app.
Things like tablet, phablet, phone display per app or per app PPI.
If you're interested in more about it, go to their (PA) website and watch their introductory videos
The soft keys don't work in tablet mode.
The different display options all work fine except for tablet mode (it makes the desktop weird and the drawer becomes 2X2
Is there any way to disable the hardware key lights?
I was using the soft keys because I prefer them more
I disabled the hardware keys in the settings but the light
Keeps staying on. Please help
Ignore the above post.
I found a way to disable it.
Use root explorer
Go to system/etc/init.d/90userinit
Then add this
echo 0 > /sys/class/leds/button-backlight/max_brightness
chmod 755 > /sys/class/leds/button-backlight/max_brightness
