Root [Port]Paranoid Android Motion[Port]
Not sure if this was covered yet here or in BobZ, but how do you get it to connect to the computer? On this this ROM it doesn't connect to computer as media storage. There is an option for camera, but that only lets me see pics. Also it only shows the internal and not the external.
It worked for me. I didn't do anything special.
If you reboot the phone and calls or messaging doesn't work is because the radio gets turned off very often. To fix this go to the dailer and type in *#*#4636#*#* then click on phone information then scroll down until you see the option to turn the radio on and click on it to fix the issues.
what works for me is just going to settings, turn airplane mode on and off.
Got to paranoid setting in setting then change to stock and phone mode
Sent from my LG-MS770 using Tapatalk 2
What did you do to make your settings bigger?
You could go to paranoid settings then apps scroll to the settings app. Go to layout/ui then in the option menu chose 360 px this will change the ui of the settings while maintaining the overall workspace settings
Been running since you released it and damn this is my favorite out of all the roms. You did a great job can't wait for updates :-)
I'm not home. And I'm on slow internet. I'll either upload later around 2-3 am or just tomorrow morning sometime.
But anyways I added Playful god's mms, new boot animation that doesn't flicker white and resized it.
Also some paranoid android default preference config changes :p
And adding some missing apps.
