Root [Port]Paranoid Android Motion[Port]
MMS Should be easy to fix. Sorry didn't know it wasn't working forgot to try. I made some small changes such as a fixed bootanimation since it flickers on this one and added stuff to the paranoid/properties.conf I'll upload everything the second I fix mms.
I'll start working on mms when my replacement phone gets here. Unless someone would like to fix it themselves. If so PM me and I'll try to help you.
:cheers:
Maybe a quick step by step from stock rooted. I get the jist of it, but haven't done it from indulge and admire. Is there anything like clear dalvick ect. format? This have wifi is it complete or a devloper rom sorry for the noobnish
Maybe a quick step by step from stock rooted. I get the just of it, but haven't done it from indulge and admire. Is there anything like clear dalvick ect. format? This have wifi is it complete or a devloper rom sorry for the noobnish
Factory reset in cmw,
Clear dalvik
Go to mounts and format system,
Go back and install the zip + gapps.
You can also do this without factory resetting.
Clear cache, system, dalvik, and install the zips.
It's not 100%
But everything pretty much works besides mms, and gps doesn't work 100%
I'll fix mms soon.
Refer to this thread.
http://androidforums.com/motion-4g-all-things-root/709736-rom-wip-cm10-0-0-l0-bobz.html
I'm gonna try this mms.apk they found and posted on bobzhome. Wanna see if it works at least, it might help us out
B4tnam tested this last night :3
Replacing mms.apk with pg's mms.apk from his latest build fixes mms.
This reminds me of when I ported ROMs to the optimus m from the optimus v. It was also PGs MMS fix that I used to fix MMS :D lol
Also, can anyone confirm that if you reboot your phone that you can no longer send text messages, or is it just me?
Not sure if this was covered yet here or in BobZ, but how do you get it to connect to the computer? On this this ROM it doesn't connect to computer as media storage. There is an option for camera, but that only lets me see pics. Also it only shows the internal and not the external.
