Root [Port]Paranoid Android Motion[Port]
I figured it out but makes rom unstable and it won't read Android/data right. Also it don't play nice with device spoofing.
Does anyone know if video calling works in this Rom? Would like top try it but need to know of that works first
I have GPS working on this rom.and bootbuddy bind script
I havent had a chance to flash the newest build yet (Half broken screen) But how did you get GPS working? That has been my MAIN concern next to MMS and SMS for every ROM ive used... Does GPS just work right after flash, or did you have to take more steps? If so, what were they in order..
Does anyone know how to get 4g data while on a call on this rom? thanks in advance
if you add the line "ro.config.svlte1x=true" to your build.prop it makes data work while in a call.
this is added to bobz build but since this is based on pg build you will need to add it manually
i cant say, i share my efforts and help but no recognition.
Are you serious, or joking? Because if your serious, then I'll find out on my own and post in detail how to do it from beginning to end. Because I see you edited the post where you wrote instructions but didn't specify...
Does anyone know what Predefined Property to choose when modifying my gps build prop. Agps said to change "ro.ril.def.agps.mode=". There isn't one in our rom. I'm trying to add it using ROM toolbox.
try ro.ril.def.agps.feature=1 ,,ro.ril.def.agps.mode=2
one after the other (not in same line)
