Clear play store, play store services, and Google services Framework.HELP I can't download apps its says not compatible with this device its all my same apps from b4 what do I do
I dl agps 3.x zip. Then extract. Go to extract and follow procedure for manual push .don't forget to reboot. If it didn't work you skimmed to fast. Please read thoroghly and ta friken dah
Shows a preview for me o.oWhen i hold the Home button to review my previously opened apps it doesnt show a preview .and can i replace the Supersuperuser ap with the Superuser app?
Maybe it's your settings?
Yes you can, but why would you want to do that?
I know it's my opinion. But I fail to realize why people choose superuser over SuperSU.
Superuser doesn't get worked on anymore. And on SuperSU you can enable pro features for free. Unlike Superuser.
i tried looking through the setting but i haven't found anything.
What could be a camera quality fix?
It might of been a matter of permission. PG gave Demon the OK to use his build as base. Not sure about Bobz.Just wondering, why didn't you use bobz cm10? Is there a reason or do you just like playful gods build more?
I'm not sure. I don't have this phone. It wouldn't matter though if it's better if there was no permission from Bobz to use his build as base.Hmm... but doesn't bobs work better?
Jellybean(Android 4.1.2)
Q: Can I port your ROM?
A: No, please learn to build from source...my github link is in "Resources".
If you view Bobz thread on the Q&A section is says
I could build from source but I'm lazy and it's faster to just use a already built rom.
So Game is right :3
Yea he said you can't port his ROM, not that you can't use his ROM to port other ROMs..... there's a difference lol
There's actually no difference, he didn't give permission, both ROMs have issues and they aren't better by much, be happy with whatever you get.
After all, there isn't much difference.
It'd be like someone telling you not to punch them, and you slap them and then say
"There's a difference lol"
