Root [Port]Paranoid Android Motion[Port]
I would like to know where he is too. I'm building version 3.60 unofficial paranoid android and I need permission to use some of his stuff
I tested this last night, everything worked as far as I could tell. I used my back up phone so I couldn't place calls, texts, or check out data connection but wifi and gps worked perfectly. I played around for a few hours and there are a few things that I don't like especially the drop down notification panel and some of the scrollability. Having a fully functional Google Now was my favorite part of it as well as most of the system ui. It packs some good features and a VERY light weight system the overall rom with the g-apps package measure only about 250MB. Overall a good rom if I were to decide to roll with it full time I'd have to edit some of the features to suit my personal preferences. Other than that great work getting it to the motion.
My test phones screen is cracked near the front camera so I just figured it didn't work because it was broken. It doesn't even work on stock for me.
I can't but i had to go into a special settings menu to get it working, which unfortunately I can't remember now. I already flashed back I'm testing a bunch of different ones out to see what I like.
So yeah guys this rom is going on pause.
I'm porting over a few new roms and will be working on them for a while.
If anyone would like to continue working on this feel free to post your own builds into this thread. I'll add them to the OP with credits to you.
Where's the link to the new build?
Go here for gps fixes. i used 3.x cwm flashable. gps locks on faster dunno about navagation havent tried this one yet. the 3.0 zip above locks on quicker but bad navagation, works but dont keep up. instructions on site
http://forum.xda-developers.com/showthread.php?t=1563226
I dl agps 3.x zip. Then extract. Go to extract and follow procedure for manual push .don't forget to reboot. If it didn't work you skimmed to fast. Please read thoroghly and ta friken dah
Woops wrong post. My bad
