Menu, Edit theme, upload/export, Select SD Card on top.
/\ niiice theme, I just am not fan of the iphone apps on the droid, but I loove it.
looks real clean...just needs different icons
great job
what time widget is that?
digital clock widget
The calendar function stinks don't waste your time. Use Pure Grid Calendar for Pure Calendar.
Good advice. That's what I did. I added a layer with Pure Grid Calendar, and another one with Pure Calendar, for the agenda view. Thanks to the transparent skins, those widgets will go with any theme I will create.
However, they do not update. I have made a few modifications, like changing the color of the text, and selecting a new starting day of the week, and nothing happened. I rebooted the phone, just to see what would happen, and now, they won't even load.
I also have added Weather Widget donate to another screen, and it's the same thing: I get the Loading Data..." message, and nothing else.
The only way to get them back is to edit the theme. However, I suspect they will not update if I modify the settings.
I'll be happy to get any clue to resolve this.
Nicolas Racine
The developer of SweeterHome has a private beta in testing that should resolve the problems you are having with the widgets updating. This is a known issue, one that will hopefully be fixed for all in the very near future.
That's good to hear.
I encountered another bug this morning. Everytime I select a contact from a contact bloc, I get a FC. I tried to delete, then create a new bloc, creating the bloc on a different screen, etc. nothing works.
While on the subject, The contact bloc could use a little more features IMHO. How about being able to select the type of contact displayed: normal, starred, one group in particular, etc. Also, adding the option to display the contact picture would be nice. That would make this "widget" a lot more useful.
Regards,
Nicolas Racine
Why not just do as I have and create a custom block, and add shortcuts to the contacts you want in that block. Then you would have pictures and the contacts that you want in that block.
My custom theme
Daihl92, that is a VERY nice theme. I am trying something similar, but I can't get the size of the icons quite right. Yours look sharp, though.
What pixel size are you using for the icons? What's the padding space?
Have you rebooted, or killed the Sweeter Home app? When I blow up icons, sometimes they look blurry .... but then they look crisp after I kill Sweeter Home and it restarts.
Getting a lot off of force closes for sweeter home .. any ideas?
I am playing with the theme Matching21.. I am trying to use the icons from the icon pack using Better Cut.. It still shows old icons instead of the new ones..
