smartmanvartan
Android Expert
No. Just do as I instructed.
If that does not work (i suspect it wont, honestly), then you will have to use stock recovery to flash the update.zip. But you MUST have stock recovery. Will nto work in clockwork mod recovery.
junkie2100's tool will root/install clockwork mod recovery. You dont want to do any of this yet. Just get it updated first.
I say dont root and custom recovery because i am not 100% that clockwork mod recovery works on the PM n861 yet.
The first post on this thread has all the info...yes the recovery works and instructions are in the first post..there is even a stable room I'm writing on...
