I checked similar threads but I couldn't get a definite answer to this. I have the DarkTremor app running on my Evo (I believe it comes with the Azrael ROM 4.0 and other recent ROMs). So, following the directions on another post, I've run the following commands using Terminal Emulator to invoke zipalign:
open terminal, type "su"
press accept
type "a2sd zipalign"
My questions are: 1) Does this command invoke zipalign even after a phone reboot or battery pull, or do these commands need to be re-run after a restart? 2) Should I still be running the apps2sd app after installing new applications to check to see if they can be moved to my sd card, or will a2sd do this automatically somehow? 3) How can I observe or measure the benefits (if any) of zipalign?
Thanks...
press accept
Thanks...
. If it comes with a ROM, you have to do everything manually. If you flashed it after the fact, it attempts to move apps and set up swap upon installation. Since you didn't have the ext partition set up, that's kind of a moot point. Anyway...
