DoctorZaius68
Is the RA_GNM Recovery v1.2.4 on ROM Manger the same thing as Drellisdee's ClockworkMod to AmonRA Update?
Quick question on this recovery....
I switched to this recovery using Clockwork, I was able to open it with no problem BUT, I can not view any of my SD files. (When I swittched back to the, Clockwork recovery they were displayed again)
Thanks in advance!
What is the breakdown of the file names used when making a backup in Amon-RA? I thought it was the date and some sort of time code, but I made 2 backups on Jan 2nd and the 2 file names ended up as:
BCDES-20110102-0539
and
BCDES-20110103-0306
Since I made the first one just after midnight on 1/2 and the second one in the evening of 1/2, I am confused by the "0103" in the second file name.
Well you are correct, its Date and Military time. However The clock is a few hours ahead for some reason. So if you do a back up a couple of hours before midnight it says you did it the next day. In your case 3:06 a.m.
You know thats a good question.... I have always wondered that. I just never got around to trying it. My best guess.... 50 50 chance. Try it.Hmm. I wonder what time zone the clock is using? I'm in EASTERN and I know we are GMT-5. Is it using GMT maybe?
Does it hurt to edit the names of these nandroid files, or might that screw things up when recovering?
Thanks!
Let me know how it went. Name it somthing stupid like Fart Knocker. LOL
Yep I just Renamed it Fart-KnockerUm, actually I had in mind to name it something more descriptive for my own purposes.
So I wonder what the BCDES prefix is all about, and if I would need to leave that in the file name, or if it is not anything essential. I use date codes similar to what they are using, but mine would look more like this:
Theirs>> 20110103-0306
Mine >> 11_0103_0306
I devised mine so that if you have a lot of folders with names beginning with these date codes, they will sort chronologically automatically, including by year. Looks like theirs will too, but I feel mine are easier to read.
It worked just great.
Wish I coulda got a pic of that.
makes me laugh. LOL
Thanks!
I think I will now Rename my stock Nandroid to.... well Stock-Nandroid. LOL
