Root RDSlite 4.8 help
jsz3us
I would like to go back to stock and I have know clue. I was at 2.3.340 and then used z4root to root. Installed apex 1.3.1. Everything has been good, I just want to go back to stock. Everytime I try to flash with RSDLITE4.8 it does not recognize my droid x. I am running RDS as admin and it still can not see my phone. Any help would be greatly apperciated!
I would like to go back to stock and I have know clue. I was at 2.3.340 and then used z4root to root. Installed apex 1.3.1. Everything has been good, I just want to go back to stock. Everytime I try to flash with RDSLITE4.8 it does not recognize my droid x. I am running RDS as admin and it still can not see my phone. Any help would be greatly apperciated!
install moto drivers and make sure your x is in pc mode and debuggung is on
link for drivers if needed
http://androidforums.com/droid-x-all-things-root/232866-sbfing-back-2-2-a.html
also do you have a backup from befor you flashed apex?if so restore it and unreoot then data factory reset
make sure you have downloaded the latest motorola drivers to your PC:
USB and PC Charging Drivers - Motorola, Inc. USA
Also make sure you boot your phone into the bootloader by pressing down the camera button, volume down button and the power button at the same time. Then plug your phone in. You should be recognized then.
so I do not need to be in the bootloader menu?
I plugged in, pt it in PC mode and still RSD does not recognize it. drivers are up to date.
Ugg that's dumb of me to say of course you need bootloader mode im sorry trying to keep up with a lot lol
