new optimus
Android Expert
I thought I seen someone ask how to remove the boot up sound at the time I was not aware of a way to do it. I have found one however.
in the folder /etc there is a file called PowerOn_standard.snd
You can rename that file, add .bak to it if you like that will stop the sound, If you wanted you might be able to put a 918K or less file in there rename it to PowerOn_standard.snd and it should play instead, I have not messed with it that far only renamed mine and got quiet boot up.
Yep tried it with an mp3, after renaming exactly it worked, though it does not play the song correctly. and it was only for a second.
