Ok so the PC36IMG file used for a number of things. It can be used to install a custom recovery, splash screens and bootanimation, radios, and finally flash a stock rom and stock recovery. It will never be used to install a custom rom, however.OK another dumb question... I have seen posts that say you have to rename the rom to pc36img, and on others it says nothing of the sort. Can someone explain when you have to do this rename?
Hi I am currently interested in rooting my Evo 4g Hboot 2.18 with the Htcdev method, but when i get to step 8 and i type in the get identifier token comand it prompts me that i am waiting on device? should my phone still be in the boot loader screen or should it be completely turned on. I am extrememly interested in rooting my phone so thanks in advance to any and all help. Thanks
Your phone actually needs to be in fastboot. so power off then press and holds power + vol down. In the bootloader menu, select fastboot. you should see the menu change from fastboot to fastboot USB.
