I believe it may have all worked. I followed all other instructions and am now waiting for the custom ROM to instal.Now I get it. I was looking for a folder named "SD" or something like this. Sometimes the simplest things get us hung up. I'm dragging the zip file now and will report back what happens. I'm holding my breath....
You're welcome and Ocnbrze is ALOT more knowledgeable than I.I believe it may have all worked. I followed all other instructions and am now waiting for the custom ROM to instal.
Thank you Mikestony and Ocnbrze!
ZZZVR_SUPERWIPE.zip link is broken
Not exactly sure what step 5 you are on. Are you on the HTC dev site?in step 5 were u got to the android file and select android-sdk then open SDK manager i cant find either of these files.... im downloading android sdk to see if this will add the files.... im missing something or a step. i have htc sync installed and downloaded all the files for rooting
welcome to the forums!!!!!!!!!!!thanks for replying so fast. i succesfuly did step 1 of the htcdev method (activating bootload ) now how do i root the phone. do i do step 3 of htcdev to root it or what? im a noob :/
Edit: i tried installing a wifi tether that requires root but it diddnt let me and said i need my phone to be rooted.
See post 1331...a couple posts up for the superwipe .zip...thanks. i thought step 2 and 3 was just for optional stuff.
Edit: Im on part 3 of the HTCdev root tutorial...the link for vvv superwipe is broken or doesnt wanna work on google chrome and further below under "after the root" tab the second link for it is at megaupload.... megaupload got shutdown a few months ago bye the fbi so can u pls re upload it, thanks or give me a link to a different one pls, on part 2 of HTCdev tutorial after u type the stuff on cmd it says it works and stuff but i see no differences on my phone
I assume you used the ADB method to install recovery.Yeah on get recovery step after I move the thing in the zip file into Android then use cmd on it and type that stuff it says some loading stuff says it took 2.6 seconds then says completed.....there's seems to be no difference to my phone though. I haven't completed step 3 of HTCdev were u flash the rom or whetever. I just wanna make sure I diddnt mess up in get recovery. So does the recovery just add a file to my phone or should there be a recovery app or something
Correct, no unzip...follow the steps and you should be good to go.thanks, i just wanted to make sure i diddnt wait all night for the rom to download all night for nothing
Edit:so the rom and superwipe is downloaded. i just move them onto the sdcard of my phone, then continue through the following steps. i dont unzip,extract them do i?
Slow internet?by the time your done with work the rom and superwiper might be done being put onto my phone cuz right now theres 26 minuts left :/
I'd stick with that awhile...Its a very nice, smooth, fast rom.im using the rom that was recomended in the HTCdev root tutorial MikG v3.11 [3/9/2012]) i got it working it looks way better then stock. for some reason it took like 20 minuts to put the rom onto my phone using a usb cord
Edit: are there any you would recommend me use, or try out?
thanks mikestony and ocnbrze for all the help.
 let us know what you think about mikg. it is a great rom. please proceed to the second post for more info about life after root. it has tons of info that will help you out.Does MikG support undervolting and overclocking
