johnathonminim
If i wanna try new roms i just factory reset then open recovery and then select the ROM and...mount it or SD card install I forgot what its called.... or do i just have to do super wipe then do the ROM mount thing install
No, but you can still flash roms/kernels etc.Hello, thanks for the great write up and info......
I'm following the HTCDev method.
Step #1 complete. bootloader is unlocked. I have on my bootloader:
*** UNLOCKED ***
SUPERSONNIC EVT3 SHIP S-ON
HBOOT-2.18.0001
MICROP-041f
TOUCH PANEL-ATMELC03_16ac
RADIO-2.15.00.12.19
Dec 21 2011, 12:50:32
For step #2, I got amon RA 2.3 loaded and was able to get into it in recovery
Step #3 , was able to run the su file using the flash zip from sdcard in Amon RA. File ran ans said "complete. Enjoy!"
I now have on my bootloader:
*** UNLOCKED ***
HBOOT-2.18.0001
MICROP-041f
RADIO-2.15.00.12.19
shouldn't s be -off?
welcome to the forums!!!!!!!!!!!!!Is there any way to get free Wi-fi hotspot with the rom you provided?
So if I use the app MikG comes with I won't be charged at all? Is the other app better? Thanks.
all the guide works perfect..today July 7 2012
I got root access...
thanyou men.
the guide was very useful easy and step by step GUI..Guides user Interface..
now I will get new rooms...
could you recommend some others rooms that works well..
thankyou..
roshririm
no worries. glad everything worked out for you. i'm also glad that you got your root and flash onHi guys
First time poster and been lurking for about 2 weeks
I had been wanting to root my EVO for a few months but been putting it off, mainly for fear that I'd screw something up and been busy with other stuff. Well, over the weekend I finally decided to take the plunge and root my phone, using the HTC dev method. Figured I'd have nothing to lose since my phone is out of warranty plus I've been eligible for a free upgrade since Jan.
I want to thank ocnbrze for an excellent and easy to follow guide
After I did the HTC dev method, I took ocnbrze's suggestion and installed Amon_RA, Mikg_3.11 and even used Pnuema's ics theme.
I had no real problems rooting my phone. The issues I had were me not reading how to c/p the token, lol and downloading some software that gave me the files I already had *sigh*
Other then that, all went well and now learning all I can do with my "new" EVO.
Thanks again to ocnbrze!
a word of warning it can become an addiction and you might end up joining us in the flashaholics anonymous program
Hey Guys,
Been trying to keep up with things on the forum, but with summer and all it's been tough. Every once in a while I run across this "smelkus recovery" but have not found much info regarding this. Just reading ocnbrze last post and I get the feeling while it's a good product there might not be overwhelming factors for me to change my current recovery Amon ra.
Just curious for you input on this, Thanks.![]()
Will this rooting method work on and HTC Evo Design ?
I have one, am trying to root but the forum for it seems to be on a dead end after that update in January. Im wondering if this method will work....
Help, please.... Anybody... lol
iam new to this but my htc evo 4g is unlock but its not rooted
Open up superuser app, open preferences and click on the Automatic response and see if it set to "prompt" instead of "deny"....Successfully Unlocked Evo and flashed recovery as well as downloaded superuser. I know thus far that the Evo is rooted because I installed busybox and it confirmed it, I also gained superuser access, however...When I install root applications superuser does not recognize them. Screenshot wont work, and the Su binary update in Screenshot has failed to gain root access, at this point i'm lost because as far as I know my Evo is rooted with S-On...what should I do? Anyone... Please.
This is a quote from this site:what dose unlocking your bootloader do.
It is set on prompt and still when ever I open a rooted app it fails to recognize it.
