Greetings and welcome to AF!yea i did everything right now im stuck at step 3 on HTCdev method
Are you on step 3 at the HTCDEv website?
or on step 3-flash su
have you tried replacing the cable? or it might be your battery. you can try replacing it.
no this sounds like something else. rom's for the most part are pretty stable and has nothing to do with charging your batteries. if anything you can try and wipe dalvik cache and cache and see if that helps. but i really think that it is your battery.Sorry should have been more clear about that, I tried 4 or 5 different chargers and all were doing the same thing. I can definitely try changing the battery, just wanted to check with you guys if it had any known link to rooting since I saw some random unreliable forum had someone blame their ROM on their battery's inability to charge
Hi again! I have a quick couple of questions for you. SHould I update the super user app from the play store? And this one probably isnt supposed to go in the post but figured you could probably answer and I can keep both questions together. It seems I need busybox for most rooted apps? I see in the play store it screwed a lot of peoples stuff up and I dont want that! Thanks in advance!
Im doing the captain throwback method but im still only unlocking my bootloader.
Greetings and welcome.I need some help here folks. So I had a lapse in thinking one day and "nearly" acceptance an OTA. I accidently clicked accept and immediately stopped it (shut off my phone etc). Well apparently it downloaded far enough to where the next time I reset my phone it installed it automatically. It didn't even tell me it was installing it just told me my phone had been updated. Now I need help. First here is the info on my phone...
Sprint Evo 4G running Ginger Bread (2.3.5), Kernel - 2.6.35.10-g4b48446. My phone is rooted, but I still have the stock ROM.
So my phone updated the software to the newest version 4.67.651.3. I know at the beginning of this thread there is an alert message about not downloading it (as with any OTA's on a rooted phone), but it did and now I'm here.
So my problem is that now I cannot send or receive MMS. It sits there acting like it's trying to send without ever sending it. Is it possible to revert back to an older software version (assuming this is what broke the MMS in the first place)? Help from any of you would be GREATLY appreciated!
RyRyV2,
How did you end up getting this to work?
I'm trying the HTCdev method and getting the '< waiting for device >' issue as well.
Debugging and Charge only turned on, in loader menu, when i choose 'fastboot' it ends up switching to 'fastboot usb' above the 'up down power to select instructions'
Thanks.
Well, what does your bootloader screen say.
Power down, wait a few, hold volume down while pressing power and report back what that screen says, and we go from there.
At least you didn't accept the latest update 5.0 something![]()
o.k..does it say "locked" or "unlocked" on the very top?It says Supersonic EVT2-3 Ship S-ON
HBOOT 2.18.0001
Microp-041f
Touch Panel - ATMEL224_16ab
Radio - 2.15.00.12.19
Dec 21 2011, 12:50:32
Sorry. It says "unlocked".
o.k...I am pretty sure you may be o.k but not sure, however,....do you have a custom recovery?
As in, hilight recovery in the bootloader screen and select it.. If you do, then wipe cache and dalvik cache and see if that helps.
If you get the red ! triangle thing, then we'll have to get you a recovery.
Not sure it this OTA messed you up alot or a little.
Do you remember how you rooted your phone before?
Gotcha, o.k. well, if you have Titanium, I would assume you have the superuser app in your app drawer. You can check that first. If that is true, you have a rooted stock rom. If you try to get to recovery, and you do not have one, you can get out of it fine without losing anything.Ok quick questions. Will there be any data loss or anything I should back up before trying the "recovery"? I'm not sure I did a custom recovery. I followed the instructions in this thread, but if there isn't a step to do it, I probably didn't. I can check though after you let me know about these answers so I don't get ahead of myself here. What gets wiped anyway when I clear the cache and dalvik cache? I do that through Titanium right?
I do remember how I rooted it. I used the HTC method mentioned at the beginning of this thread. I just never flashed a custom ROM to it. I have the stock rom. I basically rooted it to wipe bloatware and to get the titanium backup and super user stuff. I haven't spent enough time yet teaching myself about the customs ROMs etc to feel comfortable doing all that yet since this is my only phone at the moment.
Let's say you go into bootloader...then you highlight recovery and press power to select...the you get the red ! triangle thing...no problem, just hold down both volume up and down while pushing power and it will get you to the stock recovery, where you can just reboot from there.
Then we can work on getting a custom recovery which is outlined in the op of this thread.
Wiping cache and dalvik cache "cleans" stuff up and will not hurt anything.
It's a good solution to multiple problems.
Let's just say I am 95% sure on what I just wrote.![]()
Well, not sure if you can wipe cache and dalvik from stock recovery if you have that.Ok awesome thanks! So what is our first step? Try clearing the cache and dalvik cache or to try to do the recovery?
Nice, what recovery do you have. The reason I ask is because I am familiar with Amon ra or recoveries based off of that. You might have clockworkmod recovery or twrp...Ok so I think I do. I clicked on the recovery and it took me to another screen. What do I do from here?
Before you wipe, make sure you are wiping only the cache and dalvik cache.click down to wipe?
Dont wipe anything else such as boot, or system, etc...that would not be good.
o.k. good, When in recovery, select wipe, then wipe cache, it will do its thing, then select wipe dalvik cache, it will do its thing, the go back and reboot.I have the Amon RA 2.3... the one the directions of this thread say to do. So my first step is to wipe? Do I wipe from the recovery console?
Thanks,
