the sprint download link works but when i try to flash it it says aborted any solutions thanks
Try redownloading again
Did you verify your md5 before flashing?the sprint download link works but when i try to flash it it says aborted any solutions thanks
Get an app to verify md5 paste the md5 given for the zip into the app and then load the zip into it. It will tell you if they match or not.I'm sorry how do u do that?
Search md5Wat app should I use for that?
Sounds good to me,...Thanks I'm always willing to test!!!I've been thinking about releasing TWRP 2.5 recovery. The only bugs/issues is that when screen timeout is enabled you can't wakeup the device and you need a battery pull or restart with adb but it's disabled by default so unless you turn it on it won't happen and some updater scripts may need to be updated to support it. Would do you think?
Pretty excited even though the Elite isn't my daily driver. Because he's got NFC fixed which wasn't fixed in CM9 in a lot of officially supported devices/builds. When the camera is sorted out it'll go from alpha to rc IMO LOL. He's done a fantastic job in what? 6 weeks? Kudos bro. Well done. :thumbup:
phenomx4, would you be interested or opposed to uploading your CM9 builds and TWRP for the Optimus Elite to an account on Goo.im ?
I've seen that you currently have CM9 on Rom Manager under phenomx4 and getting updates on Goo.im would certainly be awesome as well.
May be an extra step for you from Dropbox on your machine or device, but it's easy from the Goo.im app and the website itself.
Try getting in touch with the guy via g+. My password got fubar and he had me going again in under an hour.I tried to get a account on goo.I'm but I've never heard back from them.
I have 3 elites ready to throw something into them lol.Once camera works I'm never going back cm all the way
Sent from my LG-VM696 using Tapatalk 2
would you be willing to sell me one of them?
Im in need of a phone bad..
Hey phenom, just a small quick fix. The setting to 'fix' the voicemail thing is in the framework-res.apk, its under res/values inside the bools.xml file. The line
[HIGH]<bool name="config_telephony_use_own_number_for_voicemail">false</bool>[/HIGH]
if changed to true should fix the voicemail thing
I know
okie dokie
<bool name="config_annoy_dianne">true</bool>
How we doing on updates?? I know its not polite to ask but is getting the camera to work and NFC feasible in a decent time frame? Like next month? Orrr?
Just wondering because im buying this phone soon for my GF and I wanted her on a fairly new version of android for her first android phone.
