Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
Can anyone help me? I am having trouble downloading and installing the gapps. I have CM 9 already installed.
Are you flashing it with cwm recovery? If not reboot into recovery wipe cache then wipe dalvik (under advanced) then flash just like you would flash the ROM.
How would I do that?
https://play.google.com/store/apps/details?id=com.fab.md5
Install md5 checker. Copy the md5 from the gapps download page and paste it into the app and then load the gapps zip and it should trek you if they match or not.
It says they don't match.
Then your download is corrupt. Delete it and try again. If they again don't match try a different browser and/or clear the browser cache. I use an app called download all files that seems to work well with downloads.
I would also like to report a bug: My friend sent me a picture via MMS and it would not download. I tried several different times on both wifi and data.
No good boot loops my phone can somone explain to me how to proporly install this...even when I had my intercept wiping my dalvik cache I seem to get cleaner flashes when I don't...I restored my backup...help
Put ROM and Gapps on sdcard
Boot to recovery
Wipe System, Data, Cache, and Dalvik-cache.
Install Rom and Gapps
Boot in to android
Wait a couple minutes, first boot always takes longest after wiping Dalvik.
After you booted in to the ROM wait a few minites then reboot again.
After that you good to go.
