currently stuck in lg logo with no other way to get a different rom on the phone because of the sd card bug, any help would be appreciated but its not my main phone so im not majorly worried.
My steps went as followed:
1.full wipe data/factory reset
2.wipe cache
3.wipe dalvik cache
4.flashed may 24th build
5.flashed gapps
7.reboot
8.stuck :/
Any ideas on the ringtone issue? I've also noticed another issue. When I was running this rom I noticed that no matter what music player I used the songs would cut in and out and skip. I reflashed sliepnir 2.4.0.3 and no songs skipped or cut out. I thought it was my music at first but running a different rom and it doesn't happen. Just wanted to put that out there. I used the same player for both roms.
ok im on sprint & I updated the updater-script & made sure the md5 sum were the same & its still not working . now it says status 4
Phenom where are u with the camera?? Did u try the kernal from cm7 this rom is best I tried so far need the camera for my lil sis graduation is there a rom that has a working camera I can use and not lose my apps?
Heres the copy of the md5 dd58f5fca93149fda74bffa1e683f204
I got the camera working in cm7. But I still had issues with liboverlay that never got sorted, so the preview in the camera app was black. It took pictures, and I think the led even worked. I had to throw our stock libcamera at idapro and read along the source code for some other similar libcameras. What it boiled down to is some enums in the header file. Our stock libcamera (and I guess liboemcamera.so) contain similar enums in the header, but a somewhere in the middle of the list of like 80 enums, there are some added. So for the first ~20 commands, we sent in the right command code, then we missed 2 numbers and every command after those was wrong by 2.AFAIK, We never got the camera to work in CM7
This rom is getting better and better. The rom keeps going slow for me though even though I've tried all the settings. Maybe my phone doesn't like cm9 or something.
Also just a thought, I accidently flashed your old cm7 rom recently and holybajebus it's amazingly fast and awesome. You should work on it againjust a thought.
I second that emotion, I'd love to test 7 out as well!!!!Where's the link for the CM7 rom? I can't find it.
I think a CM7 would be cool...even nostalgic... but when the CM9 base is stable that can/would lead to CM10, Paranoid Android, AOKP, SlimBean ports. Let's look forward not backward. Because the fact is if this device actually came out today it would launch with ICS. There's lots of entry/mid range phones similarly speced. I have nothing against the idea of a CM7 port, I just don't see the need in putting energy and work into going backward.![]()
So would they be stock or cm7?stock based ROMs could be based on CM7
Cm7 could actually bring ALOT of development. The stock based ROMs could be based on CM7, and a lot more ROMs for this phone could also be based on CM7. Then CM9 becomes stable and more ROMs are based on that then CM10/10.1 are developed and so and so for.
Serial flasher.....I think a CM7 would be cool...even nostalgic... but when the CM9 base is stable that can/would lead to CM10, Paranoid Android, AOKP, SlimBean ports. Let's look forward not backward. Because the fact is if this device actually came out today it would launch with ICS. There's lots of entry/mid range phones similarly speced. I have nothing against the idea of a CM7 port, I just don't see the need in putting energy and work into going backward.![]()
You know what would SUCK? If the ICS update came out for the Elite the day this finally got the camera working, and all major bugs out. Honestly, I don't know ICS will ever officially happen on the Elite, anyway.
Also, is there a way to get a notification when a new update for this ROM comes out?
Thinking of a couple of ways.
I've noticed in /system/app there is CM Updtaer app. You could probably use that...
That's only for officially supported devicee
