MacFett
Android Expert
Never got in as a Dev on goo.im?That's only for officially supported devicee
You know what would SUCK? If the ICS update came out for the Elite the day this finally got the camera working, and all major bugs out. Honestly, I don't know ICS will ever officially happen on the Elite, anyway.
Also, is there a way to get a notification when a new update for this ROM comes out?
Its for the entire sprint build zip fileWhat is that md5 for? The entire Sprint build ZIP file? If so, the ZIP file you have is not complete. It should be 2858f14742214ed5266663a143c1274c
If that is the md5 of the updater-script file, then I'm sorry, but I can't help. If you posted the contents or a copy of the updater-script file you were trying to use, I would have checked it for you.
You guy's are thee very best,...Thank you all for all your time & effort!!!
No. I just looked at the requirements and it looks like I need this one.Never got in as a Dev on goo.im?
Yeah, that'd be nice.Actually it would rock. Because then they'd likely release the 3.X kernel source code and some real awesomeness would happen Lol.
Which link?the link doesn't work is there some other place I ca download it
I just tried the Devhost one & it worked for me,...It might be the browser try a different browser!!!the link doesn't work is there some other place I ca download it
So does that mean that, we're always stuck with a modified version of the stock kernel, unless they were to release an OTA update?
does anybody have an idea why I get stuck in a boot animation loop?
Same thing happened to me, I had to re-flash the rom,...Make sure you do a full wipe(cache/dalvic/data & also flash the gapps!!does anybody have an idea why I get stuck in a boot animation loop?
what is the trinity?Did you wipe the trinity? Data, cache and dalvik? Also I know its an extra step but I always mount system prior to a flash, I also format the system partition when moving between GB, ICS and JB.
This is a beta release of CM9 for the Optimus Elite so please don't expect this to be 100% stable. You may get random reboots and lockups or you may not. Before flashing this rom I recommend you make a NAND backup just in case.
Is there some app or some way to get the camera usable untill its fixed?
Working on it.First off, thank you for all your work on this ROM. Its a great upgrade for a phone that likely won't see any additional updates from the factory. My one issue, aside from the camera, is the amount of RAM available, with just the basic apps running. I find most of the time I am dipping into double digits of remaining RAM and it seems to get pretty laggy when opening new applications. (I frequently get that message if I want to wait for the application or force close)
What are you all seeing?
R.
Hello everyone,
I've been reading through this thread and am uncertain whether or not my phone is capable of this CW9 method. I have a Kyocera Rise from Sprint. If it does work for this phone can someone repost the links to the files I need? It says that they will download and never download so when I click the "click here if download does not start automaticall" button and all it does is reboot the page but the download never starts. Thank you
KR hopeful
Hello everyone,
KR hopeful
Roms are device specific. You need to look in the Kyocera Rise forum. But tbh I think I've read the boot loaders are locked on your device. Good luck.
