In a drugged haze my son lost my hand me down elite. Good luck with cm on this other wise horrible device. Wish I could check out the update and continue testing but I will not buy another one of these.
So, I'm currently running sleipner, but I was hoping to give this a try.
I've downloaded the Sprint version multiple times, both alpha and beta, checked my md5s, but I keep getting a status 7 abort. Any ideas what causes this?
If you're on "Virgin Mobile" you shouldn't use the "Sprint" version!!!Did you wipe everything?
What recovery are you using??
sorry wrong post.....lolIf you're on "Virgin Mobile" you shouldn't use the "Sprint" version!!!
If you're on "Virgin Mobile" you shouldn't use the "Sprint" version!!!Wiped everything, but I see the problem, I'm on cwm 5.0, doh!. I'll update it and hopefully be up and running soon.
Reporting in to say that I managed to get the OTA update downloaded and installed. It appears to be running way more smoothly than any previous builds and I appear to be averaging around 140MB of free RAM. Definitely the best build so far.
Sent from my LG-VM696 using Tapatalk 2
My OTA updater doesn't seem to be working. When I load it, it says that there is a new update available. I click download and it says downloading. Then a popup comes up that says "Install ZIP" with the Wipe Cache checked. Then it prompts "Installing the file will reboot into recovery to flash the ZIP file. After installation, the system will automatically reboot." I click 'Install' and it reboots into recovery and runs the updater script and it wipes cache and then reboots. I go to check under 'About Phone' in settings and it still shows that it is running the 6.13 build. I click on OTA updater again and the process begins anew, always with the same results.
Mine's been doing this, too. I tried it a couple of times, then just decided to ignore it for now.
Glad to hear that. I manage to have at least 170 tob180mb ram free
