Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
What filesystem is your SD card?
I had it a fat32 but that was for my Optimus V and Kyocera Rise. When I got this phone and put my sdcard in I had to format it through stock ROM so it will read it.
I also tried formating it through this ROM and it does not format it. All my stuff is still there.
Also just curious, if you update the ROM will the CM updater do anything?
Rom seems to be running good so far, just a few random reboots, have the 1x data issue but my ext sdcard & everything else is running fine, great job to all involved.... not trying to rush anyone... just curious, has one of the devs picked up the camera problem &working on it? I want to keep the rom but a camera is crucial for me, thanx again
Dude, Phenom, you are the Shazty McShaznat! Just straight Nazty with it. Gotta say man, excellent alpha release:D
This friggin DSP manager rocks my ears off, I'm pretty sure I nearly destroyed my headphones.
...oh yea, just one, extremely minute thing I was wondering, I'm supposing that the camera has to be working in order for the native led toggle widget to work, but I don't know. I'm not harping about the camera, that'll come in due time, I'm just curious about the flashlight.
I sure the camera stuff is way too advanced for me. I would need to recruit some experienced devs . Also updated OP with the new build.
Wasn't trying to bug anyone...only reason I asked is because he mentioned few posts back that he may not be able to fix it...I was just curious if he had recruited anyone yet
As far as I know, I don't think he's got anyone yet. Usually with roms, it takes a long long time for the camera to work... which is unfortunate.
How did you guys get Google Now to finish setup? I have it flashed and installed but every time I get to a certain part in setup it just crashes.
Check to see if you have all the files for GN in /system. Or go in to recovery wipe cache and dalvik and flash again.
Or go in to settings>Apps and look for Google Search. Then clear cache, wipe Data and Force Stop.
I'll try to see what's up with the camera but me being the only dev with no experience with rom development before I'm surprised I got this far.
Just found out something kind of interesting. If anyone tried to play GTA 3 on any other ROM you probably know it was just a blackscreen with some gamesounds. But somehow this ROM fixes that problem, and GTA 3 at about 50% settings works just fine. :D
have the 1x data issue but my ext sdcard & everything else is running fines
Is it really 1x? Or is it just displaying 1x? Like the Elite displays 3G no matter what. I used Status Bar 2G-3G lite when I had my elite running to see what kind of mobile data connection I had.
Try using wifi.
Okay i tried to use the Google Now remover zip and flashed that and everthing went okay. After that i tried for one more time to put the offline version on and now Google search crashes! I am guessing that is something that cannot really be replaced so all i can do is reflash the rom?
It so thats okay like i said i will be in a building with Wifi and will have enough free time downloadlthe Apps (again).
If i does not work on the wifi i am just going to quarantine it and leave it alone!!
What I did was use a sd reader & copied & pasted it, Put the sd back in the phone..mounted it then all was good!!!
Thanks again to all involved!!!
