Root [ROM 4.1.2 - 4.2] JELLYBAM [15/12] [Jewel] [PA.AOKP.CM10] [ATOMIC]
ocnbrze
DON'T PANIC!!!!!!!!!
  • May 13, 2010
    40,475
    1
    33,612
    Los Angeles
    this is not mine
    original thread:
    http://forum.xda-developers.com/showthread.php?t=2047055
    Built from source -
    - Overall features of AOKP, CM10 and PARANOID -
    - Custom JellyBam Settings with preferences -
    - Tons of customizations -
    - Themes and Mods in JellyBam style -
    - Latest CM10/AOKP Kernel compiled from sources -
    - New Mali driver -
    - Exynos HWComposer -
    - Lockscreen with x8 Custom app targets -
    - New optimus 4x circle lockscreen -
    - Ability to customize color and alpha of the optimus lockscreen -
    - Bravia Engine libraries -
    - Bravia XLoud audio libraries -
    - Paranoid Android settings -
    - Per-App-DPI Changer -
    - Per-App-Color -
    - Custom home action and hardware button in lockscreen -
    - Quick/Long click on weather and clock actions -
    - JellyBam Panel in settings app -
    - AOKP and CyanogenMod Settings -
    - Mass storage mode -
    - Apollo Music Player (Themed) -
    - Quick SMS -
    - Init.d scripts -
    - JellyBOOM script -
    - Media quality tweak -
    - 3G and GPS Tweak -
    - RAM Optimization + Multitasking -
    - SmoothScrolling tweak -
    - V6 Supercharger included -
    - lot of Themes available in UpdateMe -
    - Trebuchet Launcher -
    - JellyBam custom Bootanimation by metallaxis -
    - Center Clock/No clock/Right Clock -
    -Volume Panel (Volume Rocker allows you to change ALL volume levels in one Menu) -
    - Lockscreen Weather -
    - Lockscreen Vibration on/off toggle -
    - Performance/Color Settings -
    - Brightness Control Slider -
    - Multilang -
    - JellyBam Style -
    - Much more! Check it by yourself! -
    - All the amazing features of CM10, PARANOID AND AOKP ALL TOGETHER-
    changelog
    Latest nightly changelog:
    project android_frameworks_base:
    * Camera: Power shooter button
    project android_device_htc_msm8660-common:
    * bcm_hcd.mk: copy correct hcd file for bcm4330 devices
    project lge-kernel-star:
    * power: su660_battery: return proper voltage value
    * regulator: Only apply voltage constraints from consumers that set them
    * regulator: If we can't configure optimum mode we're always in the best one
    project vendor_jellybam:
    * Use audio blobs from v30a (LGe devices)
    project android_packages_apps_Mms:
    * Fixed build
    * Adjusted italian, hungarian and chinese translations
    project android_packages_apps_Apollo:
    * Add Greek translation
    * Rewrite image fetching and caching
    We are working hard every day for improve and let jellybam become the best rom ever created, if you enjoy it, please, consider a small donation to us by clicking this link! thank you
    My GPS doesn't work with this ROM. I would post in the xda forum but don't have enough posts to ask there. Can anybody help or is this just not working in this ROM?
    its an aosp thing very similar to aosp for the og evo back in the day.
    so here is what you do:
    1. go back to sense rom(make a nandroid backup first)
    2. download msl reader(play store), run msl reader and write it down,
    3. go to dialer and dial ##GPSCLRX#, enter msl that you wrote down, the phone will reboot
    4. open navigation and enter an address and wait until you get a lock.
    5. it does not hurt if you test the gps out in the wild. if not then go ahead and reflash your rom or nandroid restore back.
    if it does not work after a nandroid restore then try the process again and re-flash the rom instead of restoring back to it.
    Upvote 0
    This did not work. I followed the steps exactly both doing the restore and reflash; no luck. I never even see the GPS icon with the flashing bars come on, yet it is enabled.
    Upvote 0
    When you get back to your rom, open google search>go to settings>go to privacy and accounts>go to google location settings> let google apps access your location on>exit app>go to system settings>go to location access>turn on access to my location> gps satellites>and finally wifi and mobile network location.
    I found this fix in another aosp rom thread over at xda.
    Upvote 0
    Do you ever see a circle? That is the gps icon for sense ROMs. Not sure of its all of them but it is for cm10.
    For GPS i always flash to sense, get a location lock in maps, and while on that screen i reboot to recovery and wipe everything, then flash my aosp ROM.
    • Like
    Reactions: ocnbrze
    Upvote 0
    BEST TECH IN 2023
    Smartphones
