I will post link when i get time, also i have found a fix for GoogleTTSwill be in next release unless dragonhart still wants to make one rom
Sorry, been suuuuuuuuuuper busy. Were getting things ready to open a new shop and I have like 4 computers at my office waiting for me to fix. I havent even gotten a chance to work on my own rom yet :/
I still wanna collab! No doubt, just gotta get a break lol. As I mentioned before in another thread, soon as tax season hits people are all over my shop. Seriously, unless you can do it yourself, where else can you get a Galaxy S4/S3/Note 2/3/LG G2/iPhone 5/S/C unlocked or flashed for $30? ^_^ *shameless self promotion*
Kool me and starkraving have some things in the works![]()
No one is going to say thanks for the update? Well, I'll say it. Thanks for the update! It looks really cool and works like a champ! Keep up the good work.
BTW, I'm still wondering about the process called ChameleonProvider that uses more of my battery life than anything else. Can I delete it?
Just one more request.
I like getting into my ##3282# (data) menu from the phone. I can't access it anymore from there since the kk update. Is there a way around this? Do I need the stock phone app?
i was never aware virgin had this feature, everything else works great so wont be adding, data is unlimited anyway. stock phone app will remove all theming
I use spotify on my phone constantly... So I usually.pass 2.5 Gbs, and yes it's unlimited.... But they throttle the hell out of it....
I can't play music anymore if I use this ROM, and that's crappy...
I really appreciate the good work you all are doing, and this ROM has given my phone a new life.
Don't get me wrong, I'm very very satisfied with all of it, I just need to get into that menu somehow guys...
Can someone with the new kk update try the menu for me?
Go to your phone app, dial ##3282# and tell me if the menu opens.
If it works, I probably need a re-flashing.
Are you on the kk update or cm version?
Also, use a converter online.
Go to your phone, type *zte*0# and go to meid (I think) then go to Google, type in meid converter, type it in. The msl (msn?) Is the six digit code. Write it down.
Sounds like a good way to loose service lol
I'm on the kk update. Its weird tho because after signing in to google, all the apps I had before the update started downloading on their own
That's because u picked restore apps during setup, my data menu doesn't work either, did u get weird errors when wiping data??
