Root [ROM][ALPHA] CyanogenMod 10 for the LG Connect 4G MS840
Rumour has it that Motorola is gonna be the manufacture ;)
Eww.... But o well every other Bonifac company has made they're own Nexus I fire guess it is Motorola's turn even though they make pretty much only droids as in the DNA etc. But eh its whatevs
I was going through some back menus on vv3 and I noticed is the sim card is not locked but on cm10 it is and I have no clue how 2 make the settings stick when I uncheck it ... u think this possibly could b the reason why we're not gettin 4g data.
Motorola had the best hardware. ;)
the uicc card isnt getting read at all in cm10 as far as I can tell.
Lg is doing the manufacture possibly a 2.3Ghz quad core snapdragon 600or800 processer and at least 2Gb or ram maybe 3 and a 330 andreo (idk if its spelt right or even close) not the 320 4.7-5.0 inch screen with a 1080p hardly think its gonna have a Nikon cam like the everybody has been saying and a 2.1 mp cam in the front with a big a** battery at 3300 Mah
So started snooping and forgot about this
--> CyanogenMod 10 Connect - PlayfulDroidz Wiki
So I check on it and I like the updated website and see the change log :D very nice pg hope this help someone's hope that's fading because it brought back my hope ;)
Yeah, not fixed though completely. He'll get it though. Faith in PG!
Edit: Also noted that he has data working on the lg Motion. Maybe soon he'll work on ours :D!
Edit2nd: Spec2nirvash, I think PG is gone for the day. but I wonder if you can send mms messages with that fix. :p
I can't test MMS or data anymore, deactivated my Connect to get the Premia :( I was just wondering since I can't get 0414 to boot up...
actually hroark and BobZhome got that working, I just built it too and trying to collaborate with Bob on it.
I've been using the latest update and I really like it.
The only problems I can see are:
Data
Random reboots (especially while in settings app)
Not being able to record videos (it says "unfortunantly, gallery has stopped" but pictures work)
Can't play back videos that I have in gallery
Can't play songs
Phone randomly freezes
Battery dies kinda quickly :(
Other than that, this rom is great. I've been getting a signal ever since I flashed it. I can call and text perfectly fine. Can't wait for new updates.
Thanks for all your work
Data
Can't play songs
Might be due to it being overclocked to 1.5ghz. I might suggest trying to put it back to stock speeds (1188 mhz?). If you wish to overclock, try gradually setting it higher and higher while stress testing with an app like SetCPU to monitor for stability.
Let us know if that helps... If not, it may be something else (bad flash? I dunno).
