Root [ROM][ALPHA] CyanogenMod 10 for the LG Connect 4G MS840
Lol are you trying to brick that phone?? :D
You know what? I remember a ways back, that Un1ocked somehow flashed the Verizon Lucid ICS firmware to his Connect and it actually booted up :eek: I think it also came with some major headaches trying to get that firmware off of the phone afterwards..... I myself had thought of trying that at one point.
Thats how i got this build to boot with the vs840 and it booted only problem was icons and everything were misplaced but this is when it was in a pre alpha state
Alright. But when I go in and llook at the apn file from vv5, it pretty much just blank code. It just says nothing.
So do it again. And what do you mean by misplaced? Like screen rez or LCD density is off?
Density was off because they were porting from spectrum so both screen rez and density ill try later to see what happens that is if i dont forget and i have to delete the first line of code that causes a status 7 error
I wish I could look myself. Seeing as I had VV5 on my Connect long before MetroPCS was pushing it, I may/may not have the updated apns-conf.xml - On my Premia that I use now, the apns-conf.xml looks a bit different and has T-Mobile splattered all over it. Not sure if network protocol/values changed much, if any but who knows.
I'll look at the XML on my Connect when I get home. I know that when I looked at the CM10 XML there was indeed some APNs listed, and the three that were required at the time were in there alongside many others LOL.
Maybe we can get Zandersig to upload the apns-conf.xml from his phone and try pasting that. Or we can try the xml from my Premia?
Here ya go. This can probably be pasted over the contents of the CM10 apns-conf.xml with root explorer etc..
Code:
 <?xml version="1.0" encoding="utf-8"?>
** Copyright 2006, Google Inc.
** Licensed under the Apache License, Version 2.0 (the "License");
** you may not use this file except in compliance with the License.
** You may obtain a copy of the License at
**     http://www.apache.org/licenses/LICENSE-2.0
** Unless required by applicable law or agreed to in writing, software
** distributed under the License is distributed on an "AS IS" BASIS,
** WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
** See the License for the specific language governing permissions and
** limitations under the License.
<!-- use empty string to specify no proxy or port -->
<!-- This version must agree with that in apps/common/res/apns.xml -->
<apns version="7">
      <!--DTS2012120300320  d00217025 20121203 begin modif-->
     <apn carrier="MetroPCS Default APN"
         apn="internet.metropcs"
         proxy=""
         port=""
         user="*"
         password="*"
         server="*"
         mmsc="http://mms.metropcs.net:3128/mmsc"
         mmsproxy=""
         mmsport=""
         mcc="311"
         mnc="660"
         protocol="IPV4V6"
         roaming_protocol="IPV4V6"
         feature="tethering"
         type="default,mms,supl,hipri"
     <apn carrier="MetroPCS IMS APN"
         apn="ims.metropcs"
         proxy=""
         port=""
         user="*"
         password="*"
         server="*"
         mmsproxy=""
         mmsport=""
         mcc="311"
         mnc="660"
         protocol="IPV4V6"
         type="ims,mms,supl,hipri"
    <!--DTS2012120300320  d00217025 20121203 end modif-->
    <apn carrier="T-Mobile US"
         mcc="310"
         mnc="260"
         apn="epc.tmobile.com"
         user="none"
         server="*"
         password="none"
         mmsc="http://mms.msg.eng.t-mobile.com/mms/wapenc"
    <apn carrier="T-Mobile US 250"
         mcc="310"
         mnc="250"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 660"
         mcc="310"
         mnc="660"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 230"
         mcc="310"
         mnc="230"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 310"
         mcc="310"
         mnc="310"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 580"
         mcc="310"
         mnc="580"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 240"
         mcc="310"
         mnc="240"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 800"
         mcc="310"
         mnc="800"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 210"
         mcc="310"
         mnc="210"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 160"
         mcc="310"
         mnc="160"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 270"
         mcc="310"
         mnc="270"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 200"
         mcc="310"
         mnc="200"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 220"
         mcc="310"
         mnc="220"
         user="none"
         server="*"
         password="none"
    <apn carrier="T-Mobile US 490"
         mcc="310"
         mnc="490"
         user="none"
         server="*"
         password="none"
    <!-- T-Mobile Europe -->
    <apn carrier="T-Mobile UK"
         mcc="234"
         mnc="30"
         apn="general.t-mobile.uk"
         user="t-mobile"
         password="tm"
         server="*"
         mmsproxy="149.254.201.135"
         mmsport="8080"
         mmsc="http://mmsc.t-mobile.co.uk:8002"
    <apn carrier="T-Mobile D"
         mcc="262"
         mnc="01"
         apn="internet.t-mobile"
         user="t-mobile"
         password="tm"
         server="*"
         mmsproxy="172.028.023.131"
         mmsport="8008"
         mmsc="http://mms.t-mobile.de/servlets/mms"
    <apn carrier="T-Mobile A"
         mcc="232"
         mnc="03"
         apn="gprsinternet"
         user="t-mobile"
         password="tm"
         server="*"
         mmsproxy="010.012.000.020"
         mmsport="80"
         mmsc="http://mmsc.t-mobile.at/servlets/mms"
         type="default,supl"
    <apn carrier="T-Mobile A MMS"
         mcc="232"
         mnc="03"
         apn="gprsmms"
         user="t-mobile"
         password="tm"
         server="*"
         mmsport="80"
         type="mms"
    <apn carrier="T-Mobile CZ"
         mcc="230"
         mnc="01"
         apn="internet.t-mobile.cz"
         user="wap"
         password="wap"
         server="*"
         mmsproxy="010.000.000.010"
         mmsport="80"
         mmsc="http://mms"
         type="default,supl"
    <apn carrier="T-Mobile CZ MMS"
         mcc="230"
         mnc="01"
         apn="mms.t-mobile.cz"
         user="mms"
         password="mms"
         server="*"
         mmsport="80"
         mmsc="http://mms"
         type="mms"
    <apn carrier="T-Mobile NL"
         mcc="204"
         mnc="16"
         apn="internet"
         user="*"
         password="*"
         server="*"
         mmsproxy="010.010.010.011"
         mmsport="8080"
         mmsc="http://t-mobilemms"
         type="default,supl"
    <apn carrier="T-Mobile NL MMS"
         mcc="204"
         mnc="16"
         apn="mms"
         user="tmobilemms"
         password="tmobilemms"
         server="*"
         mmsport="8080"
         type="mms"
</apns>
Code:
<apns version="7">
         proxy=""
         port=""
         user="*"
         password="*"
         server="*"
         mmsproxy=""
         mmsport=""
         mcc="311"
         mnc="660"
         protocol="IPV4V6"
         feature="tethering"
         apn="ims.metropcs"
         proxy=""
         port=""
         user="*"
         password="*"
         server="*"
         mmsproxy=""
         mmsport=""
         mcc="311"
         mnc="660"
         protocol="IPV4V6"
         mcc="310"
         mnc="260"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="250"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="660"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="230"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="310"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="580"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="240"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="800"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="210"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="160"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="270"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="200"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="220"
         user="none"
         server="*"
         password="none"
         mcc="310"
         mnc="490"
         user="none"
         server="*"
         password="none"
         mcc="234"
         mnc="30"
         user="t-mobile"
         password="tm"
         server="*"
         mmsport="8080"
         mcc="262"
         mnc="01"
         user="t-mobile"
         password="tm"
         server="*"
         mmsport="8008"
         mcc="232"
         mnc="03"
         apn="gprsinternet"
         user="t-mobile"
         password="tm"
         server="*"
         mmsport="80"
         type="default,supl"
         mcc="232"
         mnc="03"
         apn="gprsmms"
         user="t-mobile"
         password="tm"
         server="*"
         mmsport="80"
         type="mms"
         mcc="230"
         mnc="01"
         user="wap"
         password="wap"
         server="*"
         mmsport="80"
         mmsc="http://mms"
         type="default,supl"
         mcc="230"
         mnc="01"
         user="mms"
         password="mms"
         server="*"
         mmsport="80"
         mmsc="http://mms"
         type="mms"
         mcc="204"
         mnc="16"
         apn="internet"
         user="*"
         password="*"
         server="*"
         mmsport="8080"
         type="default,supl"
         mcc="204"
         mnc="16"
         apn="mms"
         user="tmobilemms"
         server="*"
         mmsport="8080"
         type="mms"
</apns>
who wants to try y not me u ask is well i need my hotspot....im also to lazy to do it right now xD lol sorry
so, this is what i've done... I installed #number two (rom) then installed ( VV5 Baseband/firmware) from here (http://androidforums.com/connect-4g-all-things-root/751012-vv5-firmware-baseband-stock-rooted.html)... after that I decided to install cmod 10 (alpha)... then i received no signal whatsoever... so decided to go back to cwm and install (vv5 baseband/firmware) . and then after two minutes later... i received a signal but no 4g ! I can make calls and text... but thats pretty much it... nevertheless, the signal keeps going up and down.....
but when i make a call i get good signal, then it shows, when i dragged down my notification bar ( that its metropcs) then when i hang up it goes away!
and that's my lastest status of what happening with my phone... maybe you guys can use this in good use! or something to fix this!
i decided to reboot my phone.. and now.. it took about two minute to get a signal! nevertheless, put it under wifi! now metropcs stays on notification and signal doesn't go up or down. it just stays steady ... but as soon as i disconnect from wifi i losse signal but gain it back when i call or text! ...
I just thought of something... As I have lost home internet, and have resorted, to things...
Anyways... I do know MetroPCS blocks user agents, specially things that don't have mobile statements in them. So possibly if the user agent in CM might be getting rejected (I doubt it, but worth a check)?
This wouldn't be the case if you cant connect to the internet another way... Like via the gmail app or something... As MPCS is only filtering user agents, for Firefox/IE... (I was able to play do windows updates, and play a MMO for a brief short time... Was not blocked when I did that)
The user agent crap for the LG Connect 4G is as follows...
User Agent: [HIGH]Mozilla/5.0 (Linux; U; Android 2.3.6; en-us; LG-MS840 Build/GRK39F) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1[/HIGH]
App Code Name: [HIGH]Mozilla[/HIGH]
App Name: [HIGH]Netscape[/HIGH]
App Version: [HIGH]5.0 (Linux; U; Android 2.3.6; en-us; LG-MS840 Build/GRL39F) AppleWebkit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1[/HIGH]
Platform: [HIGH]Linux armv7l[/HIGH]
Vendor: [HIGH]Google Inc.[/HIGH]
Gosh, can someone work on this ROM and make this dream come true... if I knew how to do it.. I would so do it.... but my knowledge doesn't go that far.
Not gonna happen the Dev has moved to another device and so did I so not much can be done now
PlayfulGod got this ROM to about 95% functional. Only issues left to fix are in the radio department. 4G and 1x will not work. If you are in a Metro area that actually has 3G coverage, it will work only in 3G signal area, but will display 1x.
This ROM is pretty much the same base as the VS840 Lucid CM10, and their data works fine. My guess would be something awry in the RIL department. I had an idea, was going to try pulling some files from my LG Motion or my Premia to see if swapping those radio/prop files out magically made data work. Unfortunately, time just didn't allow, and I have since moved on and bought a new phone cuz I got sick of Gingerbread.
If one has the time or the patience, this ROM could come to life. The answer/fix is probably right here in AF, or perhaps somewhere on XDA dev site. Fix may only involve a prop file edit. You're Android knowledge will go further only with taking chances, some experimentation and some online studying....
Since there seems to be a lot of activity in this thread about CM10 Jelly Bean, does anyone know if there is a working CM9 Ice Cream Sandwhich, I'd be fine with Even that.
Anyone know of any better roms than just the 5 listed on the root main page?
No, there isn't, only CM10. Only for MS840/VS840 Lucid, and the only CM9 out there was a project for the LS840 Viper that has been abandoned for some time now. You're stuck with Gingerbread.
If some of you folks want to toss a few bucks over my way for a month of 4G service on my Connect, I'll try a few ideas I have to get 4G going. I may be able to get data going. I don't care if I brick it either, as I have no plans on ever using it again. Just throwing that out there if anybody is interested :D
Winter means tight budget for me but I'll pitch in the time for it. And keep in mind that there is no guarantee of success...
When ever I get paid, which unfortunately is up in the air at the moment... I can toss $30 for on month of service...
Not sure how much longer I will be using this phone. I am already pretty much certain when I can my next phone will definitely be the Nexus 5. Since I am unsure when that will happen, I will keep using this phone until I am either kicked off the network or until I obtain the Nexus 5.
Same nexus 5 is gonna be my next phone i own a spirit as of now
