Yep. It'll get added in v0.6.1.
Can u please tell me how to do it now? I have loaded 0.60. Thank you.
I've been running CM9 all of today to help out with testing and hopefully provide some real-life bug reporting, and I noticed something with my data connection. It seems that the data connection will work fine, but stop working if the phone goes to sleep for a bit. When woken back up, the data connection doesn't resume correctly, and I have to toggle airplane mode to regain working data.
Essentially, I'll have my phone in my pocket for an hour or two, then try to use it. I'll notice that my signal bars are grey instead of blue, and I get no "up/down" transfer animation like I normally do. Any attempt to use the data connection at this point simply fails. Like I said, this is fixed by toggling airplane mode.
The only thing that seems like it might be related in my logcat is:
Code:F/NetworkStats( 3327): problem reading network stats F/NetworkStats( 3327): java.lang.IllegalStateException: problem parsing idx 1 F/NetworkStats( 3327): at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:300) F/NetworkStats( 3327): at com.android.server.NetworkManagementService.getNetworkStatsUidDetail(NetworkManagementService.java:1282) F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService.performPollLocked(NetworkStatsService.java:831) F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService.performPoll(NetworkStatsService.java:799) F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService.access$100(NetworkStatsService.java:128) F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService$3.onReceive(NetworkStatsService.java:633) F/NetworkStats( 3327): at android.app.LoadedApk$ReceiverDispatcher$Args.run(LoadedApk.java:728) F/NetworkStats( 3327): at android.os.Handler.handleCallback(Handler.java:605) F/NetworkStats( 3327): at android.os.Handler.dispatchMessage(Handler.java:92) F/NetworkStats( 3327): at android.os.Looper.loop(Looper.java:137) F/NetworkStats( 3327): at android.os.HandlerThread.run(HandlerThread.java:60) F/NetworkStats( 3327): Caused by: java.io.FileNotFoundException: /proc/net/xt_qtaguid/stats: open failed: ENOENT (No such file or directory) F/NetworkStats( 3327): at libcore.io.IoBridge.open(IoBridge.java:406) F/NetworkStats( 3327): at java.io.FileInputStream.<init>(FileInputStream.java:78) F/NetworkStats( 3327): at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:269) F/NetworkStats( 3327): ... 10 more F/NetworkStats( 3327): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory) F/NetworkStats( 3327): at libcore.io.Posix.open(Native Method) F/NetworkStats( 3327): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110) F/NetworkStats( 3327): at libcore.io.IoBridge.open(IoBridge.java:390) F/NetworkStats( 3327): ... 12 more
I'll see if I can get a better logcat later for someone to examine.
I had this issue on one of my old phones with a custom ROM (can't remember which one), but I used this app to "fix" it until the dev did: Connection Checker.
It seems that data has only gone down once on my phone in ~16 hrs since I installed the app (the app logs data changes). So not sure if it is actually a problem or not...
So has the "/system/bin/btwlancoex" been deleted in the recent build?
nope. I had to remove it again.
Maybe it should go on the development page so they know to add it to the next build.
This might be a noob question, but with development going like crazy on this ROM, is there a way to just keep flashing the latest ROM, retaining all settings? So far I've just been using Titanium Backup, but that can be a little time consuming. Thanks in advance! I love this ROM! It's my daily driver even without stuff working at the moment.
Titanium backup can cause problems occasionally. Just make a NANDroid backup of the ICS ROM before switching back to your daily ROM. When a new version comes out, restore the ICS ROM, wipe cache & dalvik-cache, flash new ROM + Gapps (needed step for now), reboot & it should have your old ICS settings with new version.
Don't do a full wipe between flashes.This might be a noob question, but with development going like crazy on this ROM, is there a way to just keep flashing the latest ROM, retaining all settings? So far I've just been using Titanium Backup, but that can be a little time consuming. Thanks in advance! I love this ROM! It's my daily driver even without stuff working at the moment.
Try deleting the "/system/bin/btwlancoex" file, wasn't sure if that was needed yet in CM9. If it works, then my CM7 commit should also be applied to CM9:
I don't know how to do most of this programming stuff (although I've been reading and learning along with my C++ class at college). Is there anyway we could get this fix put into the ROM so everyone can use it? That would be awesome devs. And as always. I'll be patient. Just whenever you can.
So is it just me or does the trebuchet launcher kinda suck? And let me add this is in no way a negative comment toward the devs. U guys kick much ass and I sincerely appreciate all of your efforts. I urge people if they're having problems with the launcher like lagging, freezing and such, go over to xda and download apex launcher. There's actually a thread on this site containing the links for apex and nova launcher. I've tried both and apex definitely is the apex of ics launchers so far. Check it out.
IMO it sucks as well... But you have to remember cm9 is a work in progress so the cyanogenmod team haven't got all the bugs and stuff out yet.
https://market.android.com/details?id=com.android.chrome
after installling, try out the new Ice Cream Sandwich only browser!
just came out!
That can cause issues sometimes depending on what is changed. If you have a problem though, you should always do a clean install and make sure that isn't the issue.
