I put the link for build 0.6.0 back if anyone wants to revert back to that build.
Whzyor you're always scared of everythingI'm not a fan of haptic vibrations anyway, it drains a lot of power to run the motor and causes physical stress to the device that could rattle loose weak solder joints over time. The MT is already pretty finicky. Just my personal opinion.
To me it just gives me assurance that i hit the button the first time. If it vibrates i know it picked it up. When i don't have haptic feedback i end up hitting the button too many times cause I dunno if it picked it up or not. Especially on the triumph when sometimes it doesn't pick up the first press.
So far the haptic feedback seems to be fixed in nates build. Also has anyone gave any thought to putting Nova launcher as the default launcher? It fixes the wallpaper scrolling issue and seems to run alot smoother. I know they did it in CM7 with the ADW launcher. Just a thought.
To each his own. Its working now. Thanks nate, yumbrad, mantera and errybody else involved. I can now use this along with NovaLauncher as my daily rom without goin back to CM7.
Still wondering why the cpu clock speeds are different than before. Shouldn't 1017 MHz be 1024 MHz?
Down here in Florida, it found my locale in about 5 minutes the first time. GPS seems to work better if I connect with a Wifi connection first, then go by satellites alone. It takes 1-2 minutes for a good link now.
What part of Florida..? I'm west central Florida. (Tampa area) haven't got to test ICS GPS because I'm out of state, but on cm7 it takes about a minute.
Success!
My build is working.
- Compiled from Mantera's latest source
- Fixed Hapatic feedback on capactive buttons based on yumbrad's fix
- Includes fixed GPS
- Home key works
- Enabled facebook sync hack
update-cm-9.0.0.Triumph-Alpha-0.6.2+FB-Sync-signed.zip
@Mantera The fix for the hapatics is simple. Yumbrad was on the right track. I added "VIRTUAL" to the lines for the 4 buttons in the generic.kl and qwerty.kl file. Let me know if that doesn't make sense.
My keymapping seems to still be off starting with 6.1 and continuing with this one. Whenever I press the Home button it doesnt go home and highlights whatever is on the top left of my screen. Just curious if anyone else is having this problem?
Does anybody know if AAC audio is enabled in the camera app? If not, can devs PLEASE enable it!
You believe this is the solution to the camera issue?
