Whyzor
Android Expert
1) can't do a Bluetooth transfer. Seems to always fail or get about 30% then it just stops.
Is this with screen on or off? or both?
There's a thread talking about it... Let me find it for you.
Here: http://androidforums.com/triumph-al...g-reloaded-latest-02-02-a-24.html#post3903321 5th and 6th post on that page. There is a mod, but I don't know if it works, nor do I personally care. You can try it if you want to though.
These are unrelated problems. I am not even using the default MMS service (to my knowledge)- GO SMS Pro is handling the sending. What you linked to is someone trying to send email through the stock messaging app.
Does go sms pro use a different way of sending it? Can it send larger mms or what? I have never used it so idk. I know the stock app has like a 200kb limit or something.
Apex, while being a better launcher overall, exhibits this behavior also.
It could've been just a coincidence...
I've had zero problems since the .6.3 update. The usual stuff is not working, but whatever, not the point. I'm quite happy with the 3g now, seeing that it's not cutting out. I think there has to be something weird with either the install, or how it was done to other's phones. There are complaints of 3g issues, but its still ALPHA. Best bet is to stay on CM7 until the ROM is officially Beta.
Here's how I did the first install of .5.0 alpha:
Recovery, Backup my CM7 setup/build, wipe /data (yes ONLY data), flashed ROM and Gapps from OP. Restored Apps ONLY with TiBackup. Then went back to games and such to restore data for the games (can't be loosing my place now).
All apps and data since the .5.0 build have been-- Recovery, Flash ROM (NO WIPE- none at all), Flash Gapps right after, Reboot. Everything has worked fine, no real major issues to speak of. If you flash Gapps before booting the first time, you shouldn't have to re-input all your information (I didn't).
When you say no major issues you don't mean camera or voice commands Correct? Cause cameras kinda critical atleast in my work
And those are known to not be working. If you need either of those, there are plenty of other ROMs that have them working.
i finally made it from cm7 to cm9. thanks to all the devs
btw is there any way to have more toggle options for the power widget like on cm7?
i used to toggle mobile data frequently.
System settings>system>notification drawer
I realize that he stated it like everything was working. Did I forget Hdmi?
sorry i meant the power control widget that you can place on the screens.
Also if it's not too much asking can you add some sort of file manager along the preloaded apps. I back up with titanium and have the apk on sdcard, so it will be faster to swap information in between flashing.
I don't see the point to it when you have access to the widget power controls in your status bar but yes, its there. Open your app drawer, click on the Widgets tab. They are sorted alphabetically, so it will likely be close to the last page.
