There are no settings for the widget as of yet.
I don't use the desktop widget, so I didn't know, sorry. I've been hooked on the notification bar widget since CM7.
Wifi is listed under both working and not working. Also has anyone tried the chrome beta?
11 hours 55 minutes on battery with data on all the time, and wifi and gps on and off... cm9 is really a beast. Everything that is supposed to work works for me. All i do is flash the update, and restart(no wipe). It gives a screen that says "android is updating", and after that everything is peachy. no issues that aren't supposed to be issues.
o good glad its not just mine. Was debating using the car door mod on it to fix lol
poweramp is better imo. DSP manager doesn't boost bass as good as poweramp does without it being distorted up the butt, unless it's at low volumes (which isn't fun when you're on a loud bus.) Unless I'm missing something here...
Anyone else's wifi not work? It's just stuck on turning Wi-Fi On...
Seems I have no MAC address either.
I've tried several flashes.
Try rebooting
i have rebooted 3 times trying to get wifi to turn on, still no go.
Really? Do you use it really sparingly? I lost about 20 percent an hour at work, but today was boring as hell and I was on my phone the whole time. That and I just got my phone, so I'm in that new phone phase where I barely put it down.
Not really... I used it more than usual really just to see. I noticed that using the built in app killer somehow makes the battery life worse if that's possible... Idk but I definitely took a major hit, and I wasnt doing anything
