Raptor5150
Yep, that's exactly what my change looked like as well. You are good to go in the next build. Whenever that is...
Mantera you know what Gary had the nerve to say.. after I said maybe it was user error at one point.. those numbers could have been easily mixxed up..
He said
I'm not adding an incorrect fix to the original post just because it works on a single broken ROM. I do not condone such hacks. Get the ROM author to fix the scancode issue on his end and it will work for everyone
Your scancode mantera cause its sooo wrong! *rolls eyes*
Thanks for helping me man
I think your scancode is just fine whatever it is.. and the rom is amazing ^_^
Oh and we must be pretty 1337 haxors if we fixed a mapping problem lol...
It's fine that people post them
It would be good to know that others have the same issue, and that this being an early alpha the reports don't help the devs a ton as there are going to be a massive amount of issues regardless.
