tusing
Mine syncs just fine.
Same here. I have no problem with the calendar. Factory reset if you do?
Oddly, my google calendar is not able to sync on the account. (check your settings??).
I realize this is alpha. I was able to live with it until I noticed no calendar sync. back to Miui until we progress i guess.
Awesome job devs!!
I am on 0.6.5 and my calendar syncs.
I'll try to reflash and see if that helps
Damn... no luck. Don't really want to wipe and than reload all my apps. Any ideas???
I just checked a realized my calender isn't syncing either... WTH. It was on earlier versions. The option isn't there????
I've noticed issues with this Rom seem to be user specific, it only affects certain people, by chance. I've had texting issues while flashing 2 different releases, nothing helped fix the issue, some others had the same issue, others had different issues, and others had no issues whatsoever. I don't know why this happens but I don't plan on flashing again until most issues are worked out, I suggest the same to you. And I suggest you buy Titanium Backup Pro, reloading apps w/ their data are a breeze.
You can make NANDROID backups of your stable ROM in recovery mode, then factory reset & flash to ICS alpha, do one-time setup of apps & settings on ICS, then make a NANDROID backup of it before restoring back. Next time a new ICS build comes out, just restore the ICS NANDroid backup, wipe cache (not factory reset), & flash new build, it'll keep your settings & run on newer code with less problems.The issues I've had all took place after flashing the rom, full fresh flash, no TBP restores when the issues were present, clean SD card, wiped cache, wiped dalvik, full data wipe. I believe it's a Rom issue coming up randomly for certain users, a bug within the Rom coming up during certain flashes. Me not being the only one having the issues and others having different issues while following the correct steps shows it's a Rom issue showing up on certain occasions. I thank you guys for the tips but I know how to flash Roms correctly, the issues I've had are Rom issues.
A ROM issue wouldn't happen here and there for only a select group of people unless there was some sort of difference or some sort of network issue specific to certain areas. If everyone flashes the same software the same way, the results will be the same.
There are many other things that can cause it besides the ROM itself (even though that gets blamed most often).
Well, if it is an issue in the ROM, everyone would be able to replicate it if they follow the same steps.A ROM issue wouldn't happen here and there for only a select group of people unless there was some sort of difference or some sort of network issue specific to certain areas. If everyone flashes the same software the same way, the results will be the same.
If you can replicate the issue and share the steps to do so, then we can replicate it. If it can't be replicated it is most likely a network or app issue (or something happened differently during the flash). It could also be some sort of setting change that is different from one person to another.There are many other things that can cause it besides the ROM itself (even though that gets blamed most often).
I am not saying that you don't know how to flash a ROM. And I am not trying to be a jerk, but if it can't be replicated it is something besides the ROM.![]()
If this is the case, something must've went wrong with the flash during 2 different releases and a reflash for both releases I flashed. Something didn't go wrong with the flash 4 times for this specific Rom by coincidence. Never had issues with any other Rom I've flashed on this phone until this one, following the same steps I always follow.
I'm pretty new to the Adroid scene but have been flashing since TG's CM7 started releasing and no problems. I didn't use Titanium Back-up because I do know there can have issues going from rom to rom. Later I will do a complete wipe and reflash 0.6.5 with the gapps. The gapps at the beginning of this thread I assume are the most current is that correct??? After that we'll see if I screwed something up or if it happens again. It's all fun and games... right?
Exactly. If you check the Sync option. it doesn't exist on there. It's not killing me or anything but I use the calendar extensively with my wife. So I had to table it for now and go back to the 2.3.7 Miui until it gets re-added.
Note: I did not reflash and try again because I was on my way to an appt. So if someone else has this issue and does reflash, can you let us know the outcome?
thanks in advance,
How often should I check for alpha releases?
