For me, battery has been better than MIUI, even though I don't use Juice Defender with CM9.Battery life is not as great as it used to be and I am wondering if that is wifi related? Battery life worse than MIUI.
The Email app should be able to do this.You can set it up as a widget. I have issues with yahoo mail though. I had a unified gmail and yahoo inbox to begin with.It worked for a few days then started to say that my yahoo password was wrong.I do miss the IOS concept of a single inbox or single icon to get all of your email (gmail and pop3)
The Email app should be able to do this.You can set it up as a widget. I have issues with yahoo mail though. I had a unified gmail and yahoo inbox to begin with.It worked for a few days then started to say that my yahoo password was wrong.![]()
I use k-9 mail and have all my emails in one place.
Never, ever use a task killer. Wise Isaacj87 advised me to read this article on why:
Fresh Rom – CDMA Android Development FAQ: Why You Shouldn’t Be Using a Task Killer with Android
The only "task killer" you should use is Autokiller. Advanced Task Killer is "unhealthy" for Android and it's Linux base.
This has now become a daily user since the hotspot is working. The launcher gave me big problems on this build, that it had not before. I switched to NOVAlauncher after reading the posts here and it is much more stable.
I use Seven Mail. True instant push notifications and it's not a battery or resource hog.
It handles ALL e-mail accounts.
Is that the name of it? Can't find it in the market.
Ahhh zRam compressed all the way and purging assets checked... + moderate OC makes this rom sooooo smooth... I highly recommend using these options
For us newbs, would you mind describing how this is done? OC'ing I get, but the first two suggestions I am unfamiliar with.
Performance -> Memory Management
don't check purging just yet..I started getting forced reboot's alittle bit ago.. if that happens uncheck it but test it for yourself.. zRam is still ok at 28%
Oddly, my google calendar is not able to sync on the account. (check your settings??).
I realize this is alpha. I was able to live with it until I noticed no calendar sync. back to Miui until we progress i guess.
Awesome job devs!!
bluetooth and wifi - do they conflict in cm9 like in cm7?
