JollyRoger87
me as well tryed flashing trans market but had no search button
Me too but you can just use the phones search button to get around this
This might be coming out of left field but when running cm9 does anyone's phone get hot? I know that when I've installed it, a couple of times, it will physically get hot in or out of my pocket
just a quick note this may have been stated before but, when you miss a call voicemail notification does not remove itself from the notes after checking. (AKA the icon is still in the drop down bar. ) its not really a problem for me but i wnated to make a note oof it to the devs so they can correct it. and as always thank you for the hard work on this rom.
Mine goes away just fine.
Thank you for your response. There is an app from Market that can tweak the minfree settings. I won't mind using that in the meantime. Once the camera is working I will be installing this! SO excited! This is progressing faster than I ever imagined!![]()
OCing doesn't work... At least last time I heard it didn't work.
Don't know what to say about that. I can see the clock speeds changing, but I guess that doesn't mean they really are. Graph looks like they are, according to settings and gov selected.
Try using antutu benchmark...
Also, hows the audio playback through headphones?
Using Google music was good today. I have it hooked to my radio at work. Sound is pretty clean.
Quandrant has just been updated to support multiple cores and ICS. Maybe the scores will now be more accurate.
I did just notice a bug though when backing out of this app. The long-press kill isn't working on the back button anymore. Anyone else have this bug or is it just me? It worked for me just fine with the 0.6.4 build.
I tried it for a bit, was happy with it, but it only works for a bit then crashes when I try to open it from there on out.
I could also only get it to install by manually moving it to /system/app. Anyway else it wouldn't work.
I gave up on it![]()
