hey guys stop complaining this is a alpa build . Once it gets to beta then you can start your moaning and groaning. Give the dev time they have come a long way in a short time and deserve some respect
Ok wifi cutting out with 0.6.5 aka voice input fix is REALLY ANNOYING..
Did I miss something? I don't see a 0.6.5 update in the OP...
I could get the link to 0.6.5? Please?
The voice input fix has nothing to do with WiFi. I am not having any issues with WiFi cutting out. Try wiping everything and flashing from scratch.
I had that issue too you have to install google voice search from app marketCall me stupid, but I updated from 0.6.3 to 0.6.5 (I just installed from zip) and I don't see that little microphone that lets me do audio-to-text input. Did I do something wrong?
Changelog:
-enabled battery % in notification bar in the Settings.
-Also enabled joystick/xbox360 controller support in the kernel - may be helpful for OnLive Controller
SWEET! very surprised by these ! Thanks mantera clean wiping now!![]()
I would like to make a note that the L.E.D. is not working. I want to use it as a flashlite. I think it should work without the camera working, rite??
I also have a flashlite app too. It just uses my screen.
